Your towing rigs and trailers
   / Your towing rigs and trailers #2,585
The trailer weights 7,000 pounds and has 12k axles. There was nothing wrong with the PJ trailer. I use a trailer daily with my rental business and wanted the extra weight capacity for safety and to be able to carry 2 excavators at the same time.
Thanks for checking it out.
   / Your towing rigs and trailers #2,586
What kind of class license is required to pull this fully loaded?
   / Your towing rigs and trailers #2,587
Nice setup. Good idea on the wood deck so you aren't inclined to have to protect the deck each time you set a blade or bucket down. I had an aluminum deck once and I was always stressing about messing it up.
Did you go with the electric over hydraulic disc brakes? I went that route with my new Diamond C with 12K axles and it sure stops nicer than the normal electric brakes.
   / Your towing rigs and trailers #2,589
I went with electric over hydraulic. Can lock up all 8 tires with power setting above 6. Had to rewire the tow vehicle to get a 10 gague wire back to the actuator.
   / Your towing rigs and trailers #2,590
couple recent ones
dad;s suburban with his new JD 2210
my extra truck towing ~9000 lbs for some baseline numbers after adding a trans temp gauge
2009 Ford F-250 Ext. Cab Enclosed Service Truck (A53422)
2009 Ford F-250...
2019 Dodge Charger Sedan (A55853)
2019 Dodge Charger...
2024 Schulte 5026 Batwing Rotary Cutter (A55314)
2024 Schulte 5026...
John Deere 4510 (A53317)
John Deere 4510...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
2023 John Deere 325G Track Loader (A53485)
2023 John Deere...
