What is this?
   / What is this? #1
kuschneider
St. Charles, MO
Ford 4000
1963 Ford 4000 Gas Row Crop S-O-S
What is this plug? Under right heel under floor board.
Tranny has a level check plug further forward in front of my right foot.
Hyds have a dipstick
Differential has a level check plug on rear left side of differential house(At least thats what I think it is)
So what is this little gemster?
Thanks
   / What is this? #3
Looks to me like a fluid level check to me.
   / What is this? #5
Hard to tell which way the picture goes but I'd agree on the fluid check plug if I have my head turned correctly. :rolleyes:
   / What is this?
Well, I was thinking the same thing, but I have a dipstick to check hydraulic oil, another fluid check for transmission, plus another for differential? What else is there? Does the hydraulic have a fluid check plug and a dipstick on a 63 Ford 4000?
   / What is this? #7
take it out a see ... Could be just a way of draining if you overfill . some engineers actually have some common sense .
   / What is this? #8
I don't know anything about this particular tractor, but some gear cases are arranged such that they have separated volumes and require multiple level check points.
   / What is this? #10
A guess.... Could it be a port for pressure testing or a port for returning fluid back to the sump from auxiliary device/valve?? Where's Soundguy?
SimS
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
17101 (A55851)
17101 (A55851)
Cushman Electric Cart (A55851)
Cushman Electric...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
