Tig welding cast iron
/ Tig welding cast iron #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
I've seen quite a few threads on welding cast iron. I posted this question over on Welding Web. And watched a few videos on You Tube. And did a little reading on the subject.
Got some 1/8" A2 Aluminum Bronze yesterday. I ordered 1/16", and 3/32". But the Post Office lost those rods.:mad:
I did a fillet weld on 1/4" flatbar. Set the Dynasty 300 on AC, and at 150-AMPS. I read where Jody set the balance at 95%, so this is what I did.
As you can see the 1/8" rod was a little big to weld the pipe cap to the coupling.
Never done this before. Pretty :cool:
TIG Welding Cast Iron
/ Tig welding cast iron #2
Just saw this topic over on WW. Some really nice links were supplied on the topic. Nice results. How does one keep from getting into the base metal with TIG though. I guess I need to watch Jody again.
What I learned along the way, was just heat the base metal enough to melt the filler. Couple times I melted the base metal before dipping the filler rod.:eek:
I was shocked how easy this stuff is to run!:cool:
/ Tig welding cast iron #4
It IS pretty--beautiful bead, in fact!
Amateur Question: If the base metal is not actually puddling, isn't this technically brazing (as one would do with oxy-acetylene) rather than welding?
Thanks,
My Hoe
Yes, it is. But brazing doesn't roll off my tongue as easy as welding. :D
/ Tig welding cast iron #6
Do you absolutely have to have AC to make this work or would it work on DC? Or would siclicon bronze be more the ticket for DC?
/ Tig welding cast iron #8
Nice welds-oops i mean braze/tig
that is interesting filler rod , looked at some on ebay and the description of uses included repairing ship propellers,bearings and even piston heads.
/ Tig welding cast iron #10
Yes I had watched Jody's video a while back. I watched it again to see what all I forgot. Silicone bronze works on DC and he runs beads with DCEN but the aluminum bronze pretty much needs the AC according to Jody.
Jody has forgotten more about welding than I'll ever know!:eek:
the amperage ranges listed were eye opening for the 1/8 rod- 300-640 amps!
I seen that!:shocked:
I set the Miller Dynasty 300 to 150-AMPS. Only a few times did I have the foot pedal all the way down.
/ Tig welding cast iron #14
Nice welds! 150-AMPS seems a lot.
/ Tig welding cast iron #15
I have repaired countless cast iron parts using silicon bronze filler and DC with a TIG.
/ Tig welding cast iron #16
Jody on YouTube makes tight look easy. It's not that easy for me doing 6g tube under the tube.
Indian Statue (A62183)
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
2020 Kubota RTVX1140 (A62183)
2020 Kubota...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
JOHN BLUE 300 GALLON NITROGEN APPLICATOR (A63290)
JOHN BLUE 300...
