Here's why you grease your loader faithfully.
   / Here's why you grease your loader faithfully. #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Here's why you pay attention to greasing loader pins and why plugged grease fittings mean pay attention now and not later. Look at this picture of the pin out of a 2002 Kubota M6800 loader with only 400 hours on it. I posted photos in another thread but this is more direct. The enlarged photo makes it look worse than it is but it's still very bad. Had it worn the boom cylinder were talking serious replacement $$for parts.
The owner greased every 10 hours like he should but one zerk was plugged and he must have thought he would get it next time. The other pins are all perfect and show little to no use with zero wear and only slight discoloration of the metal. The damage is hard to believe --and I bought a new pin---but the bushing looks fine. This is off the boom cylinder and this was the pin on the pillar post. It wasn't even in the dirt.
So if something is not taking grease, figure it out. Plus, I often grease my loader and other severe wear points more often than suggested. And if I see a tractor with grease all over the loader pins I know it's likely being better cared for than one that's hospital clean. My two cents.
   / Here's why you grease your loader faithfully. #2
Yep, I don't have much to add. You pretty well said it all.
   / Here's why you grease your loader faithfully. #3
I think that's why they're making the pins soft and the bushings hard. It's easier to replace the pins than the bushings.
   / Here's why you grease your loader faithfully. #4
Good post... I have been meaning to checkout one of my backhoe fittings... it the hoe sits for an extended time it sounds "Dry" the first time it moves.
Don't like grease oozing everywhere but my boss liked to see it to make sure it was getting done.
   / Here's why you grease your loader faithfully. #6
That had to be making horrible noises ..for quite a while.
Take the pin out, replace it and clean everything around it. I bought a new-to-me tractor recently and took every pin out and cleaned it. Now I know what I've got.
Post what you find
   / Here's why you grease your loader faithfully. #9
I think I'll go and grease my loader.
Not a bad idea, and with a lockNlube coupler it doesn't take long and grease is pretty cheap compared to parts. :)
   / Here's why you grease your loader faithfully. #10
   / Here's why you grease your loader faithfully. #11
The owner greased every 10 hours like he should.........
I grease my loader every ten hours. Sometimes the timer goes off in the middle of the night, but I dutifully get up and grease it anyway. I go through a lot of grease.
   / Here's why you grease your loader faithfully. #12
Post what you find
Backhoe is about 800 miles away... it will be awhile until my next visit.
I really should sell it but it's just too handy to have around once you are use to having one.
   / Here's why you grease your loader faithfully. #13
Check out that Persid meteor shower while you're out there tonight.:laughing:
   / Here's why you grease your loader faithfully. #14
If the shower is a good one with lots of meteor's you can make some nice long distance contacts on VHF and UHF frequenciesby bouncing your radio signals off of the ionized trails they leave in the ionosphere. (fun filled useless factoid:) )
   / Here's why you grease your loader faithfully. #16
When I picked up my IH 244 about 18 months ago about 2/3 of the zerts on the KMW 95 loader were broken or wouldn't take grease. But, about half on the tractor were the same way. The previous owner restored cars, so I don't get it. Why not take care of your stuff? A 5 foot Howse disk I picked up locally appeared to have never had any grease applied to the gang bearings. Luckily it hadn't been used much. My Dad taught me to take care of my equipment. Even though he was farming for a living in Eastern Iowa, and I am only gardening and putting in food plots in South Alabama.
Bill
   / Here's why you grease your loader faithfully. #17
One of these helps keep things greased.
Between the loader and the backhoe it's getting well used.
You sure that pin doesn't have some type if design flaw?
It's a simple loader pin like all the others on the loader. None of the other pins had any wear on them. The worn one had a plugged grease fitting and was dry of grease so I'm pretty confident that's the issue.
I have seen bad pins before but not in a long time.
   / Here's why you grease your loader faithfully. #19
   / Here's why you grease your loader faithfully. #20
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
5th Wheel Hitch (A59230)
5th Wheel Hitch...
UNUSED JCT 72" HYD 4N1 BUCKET (A52706)
UNUSED JCT 72" HYD...
Bobcat T590 (A53317)
