Here's why you grease your loader faithfully.
   / Here's why you grease your loader faithfully. #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Here's why you pay attention to greasing loader pins and why plugged grease fittings mean pay attention now and not later. Look at this picture of the pin out of a 2002 Kubota M6800 loader with only 400 hours on it. I posted photos in another thread but this is more direct. The enlarged photo makes it look worse than it is but it's still very bad. Had it worn the boom cylinder were talking serious replacement $$for parts.
The owner greased every 10 hours like he should but one zerk was plugged and he must have thought he would get it next time. The other pins are all perfect and show little to no use with zero wear and only slight discoloration of the metal. The damage is hard to believe --and I bought a new pin---but the bushing looks fine. This is off the boom cylinder and this was the pin on the pillar post. It wasn't even in the dirt.
So if something is not taking grease, figure it out. Plus, I often grease my loader and other severe wear points more often than suggested. And if I see a tractor with grease all over the loader pins I know it's likely being better cared for than one that's hospital clean. My two cents.
   / Here's why you grease your loader faithfully. #2
Yep, I don't have much to add. You pretty well said it all.
   / Here's why you grease your loader faithfully. #3
I think that's why they're making the pins soft and the bushings hard. It's easier to replace the pins than the bushings.
   / Here's why you grease your loader faithfully. #4
Good post... I have been meaning to checkout one of my backhoe fittings... it the hoe sits for an extended time it sounds "Dry" the first time it moves.
Don't like grease oozing everywhere but my boss liked to see it to make sure it was getting done.
   / Here's why you grease your loader faithfully. #6
That had to be making horrible noises ..for quite a while.
Take the pin out, replace it and clean everything around it. I bought a new-to-me tractor recently and took every pin out and cleaned it. Now I know what I've got.
Post what you find
   / Here's why you grease your loader faithfully. #8
I think I'll go and grease my loader.
   / Here's why you grease your loader faithfully. #9
Not a bad idea, and with a lockNlube coupler it doesn't take long and grease is pretty cheap compared to parts. :)
   / Here's why you grease your loader faithfully. #10
NEW Wolverine Skid Steer Pallet  Fork Hydraulic Adjustable (A59000)
NEW Wolverine Skid...
yellow ball Trailer (A56859)
yellow ball...
2014 BRENNER CRUDE TRAILER (A58214)
2014 BRENNER CRUDE...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A58018)
2018 VOLVO VNL...
Moxy MT30S Haul Truck (A55272)
Moxy MT30S Haul...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
