Used F3060 issues
/ Used F3060 issues #1
Rovcketman357
Member
Shoemkersville,PA
F3060, L3600 GST
Just bought a used 2002 F3060 with 72 mower and GCF-30H grass catcher with 2400 hours.
1. "Idle" is awfully fast - guessing 1500 RPM-ish and nuts at linkage would seem to indicate it is as set at the factory - no wrench marks on paint. Is that normal?
2. Lift seems to be erratic - sometimes normal and other times does not want to lift. Lever does not self center to neutral position- I wonder if that has caused a problem? Otherwise hydraulics seem fine.
3. I cannot find the grease point for "HST Neutral Shaft" from the pathetic illustration in the owners manual. Any help? [I think I have attached the page referenced.]
  • Kubota F3560 Owners Manual 40.pdf
/ Used F3060 issues #2
Don't think there is one. At least not on mine which is the newer model.
/ Used F3060 issues #3
I used to have a F3060....It idled quite fast...think they set it high to prevent engine stall when engaging the mower..Never an issue with the lifting. Had about 2800hrs when I traded it.
/ Used F3060 issues #4
Did you ever figure out what was wrong with the lift? I rebuilt mine but it seems to also work erratically and my mower drops on it own.
/ Used F3060 issues #5
I just replaced my throttle cable on my 3680 (very similar to 3060) and thought it was easy to custom tailor idle.
2461 (A58376)
2461 (A58376)
Arrow Quip 5500LV Cattle Chute (A64047)
Arrow Quip 5500LV...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
ASSET DESCRIPTIONS & CONDITION (A59910)
ASSET DESCRIPTIONS...
2022 John Deere Z930R Zero Turn (A63116)
2022 John Deere...
2015 ISUZU NPR 4X2 16FT BOX TRUCK (A59912)
2015 ISUZU NPR 4X2...
