Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #3,221
I should correct myself before someone jumps my case. :)
When I said, "Going forward means the grass is cut at the base like a rotary cutter", that's actually incorrect technically. The grass blades are cut several times by the flails in an arch. This is why the grass coming out appears to be chopped fine. With a rotary cutter, the grass is cut at the base but stays under the deck until it's fine enough to exhaust or be thrown out in clumps.
It can be pouring down rain and I can cut grass with the flail mower without clumps or significant build up under the housing. Try that with a rotary mower.
I have, 7' rear discharge finish mower behind our L3830. Mows just fine without clumps as long as you are mowing "lawn" length grass, not "hayfield" length grass.
Aaron Z
/ Let's talk flail mowers #3,222
Copied from an Alamo brochure, the shaft is rotating same as tires:
I stay confused without thinking about forward & reverse rotation but that's the way my mower is running now. Thanks to all for the info. Until I get me a operators manual I'm somewhat lost at this flail mower stuff. So far I really like it but as I said maybe in another thread I'm keeping my finish mower and my rotary cutters. I'm not sure about the other mowers but the Mott 72 can run either forward or reverse and the knives have the cutting edges on both sides. If you just run it in one direction I guess you just turn the knives around once they are beyond sharpening.
/ Let's talk flail mowers #3,223
I admit do not read every page of this thread but do keep dropping in it. No idea who's manual I read but think an Italian flail mower (boom model) that said to use the direction of rotation where the cutter was cutting the front side of the item meaning it was pushing what it was cutting towards the ground or away from the top of the cutter if it were like limbs or such so it would not pull it and jam the machine. Grass you ran it where the cutter rotation was backwards to the travel direction to keep the grass in there to cut as fine as it cut. Made sense to me. That boom mower had hyd reversing control for the direction and thus easy to change. My current boom mower does not and I plumbed it to rotate same direction as tire travel forward and it has worked fine.
/ Let's talk flail mowers #3,225
Oh I see what they have to do with those "backward" cutting mowers. :) They have to add that Quasimodo hump on the back to deflect the debris down. Wasted metal and energy.
I got it. We'll forget about the forward or reverse rotation and just call it the right way and the wrong way.:cool2:
If it's cutting the grass that's the right way. If it's makes the grass taller that's the wrong way.
/ Let's talk flail mowers #3,226
He, he, he. :thumbsup:
I'm old and my equipment is old but it works for me. :drink:
/ Let's talk flail mowers #3,227
It's on the trailer.:cool2: image.jpeg
/ Let's talk flail mowers #3,228
It's on the trailer.:cool2:View attachment 475817
Welcome to the Flail Mower Nations Greenland South.
Being a residient of the Flail Mower Nations does not require the paying of Poll Taxes, Vehicleor Ship Tolls or utilities expenses charged to its residents. No Passport, Birth Certificate or drivers license is required to enter or exit the Flail Mower Nations through its beautiful German Styled Beer Garden entrance to visit any other nation.
Be sure to use a torpedo bubble level and and place it on the top of the gearbox
to level the front of the flail mower before your first mowing.
With the shredding bars installed at thier lowest setting you will get a very fine clipping of any limbs and thick brush that will degrade quickly.
Happy Mowing.
/ Let's talk flail mowers #3,229
Nice looking machine, Greenland
/ Let's talk flail mowers #3,231
What are all the rods with the clevis pin in them. Have not seen that before
I believe they are what Leonz referred to as shredding bars. I guess they hold branches and other debris in the cutting drum so they are chopped up? I have a lot to learn, I'm sure.
/ Let's talk flail mowers #3,232
On thing to think about is how reverse rotation tillers rotate and throw dirt at the tractor - from the side they rotate clockwise or to the right. The same goes for a reverse rotation Flail - rotation is that the knives rotate clockwise and run towards the tractor on the bottom of the arch. Normal tiller and flail is counter clockwise or the tines/knives rotate up over the top of the drum arch towards the tractor. In the case of the tiller they would push the tractor as they enter the ground. Hope this helps.
Bottom line, if it throws debris in the cutting/tilling action towards the tractor from the bottom, it is reverse rotation. That's how I remember it.
/ Let's talk flail mowers #3,233
Thanks. I read an old brochure Xfaxman posted it(not exactly an operators manual) and it called the rotation you're explaining Standard Rotation the other direction was called Reverse Rotation. It shows a picture showing the cutting edge when its close to the ground going toward the back of the mower, this is the one Mott called standard rotation but it never mentions why you would run it in standard instead of reverse. Lots of mowers run in reverse only and some run in standard only. Is there an advantage one over the other. Arc weld (post 3206) gave an explaination and Reg (post 3208 gave his explaination.
The Mott 72 will run in either direction so one day when curiosity gets the best of me I'll switch the gear box around and see. I've had everything loose while replacing bearings and giving the old thing a once over so I'm familiar with it and looks to be about a 2 hour job (using the overhead hoist). If I do I'll post back with the results.
/ Let's talk flail mowers #3,234
I have looked over this MONSTER thread and didn't see where anyone has owned a Woodmaxx flail mower. I'm considering one for use in several roles.
1. As a light to medium duty brush cutter for material up to about 1.5in in diameter but mostly berry brambles.
2. To cut up to 10 acres of clover, alfalfa, buckwheat, wildflowers, and similar plantings a couple of times a year.
3. Cutting tall grass from under-attended areas several times a year.
I think I'll want a machine with hammer knives rather than Y grass blades. I'm not looking to cut super short or get a particularly groomed look, but a rotary cutter leaves windrows that I'd like to avoid. Where I mow there are occasional bowling ball sized rocks and old stumps. The rocks I'll remove as I find them, but I wouldn't want hitting such a rock to cripple the mower. The stumps will either be mostly rotten, or I'll dig them out as needed.
I'm looking at the 77in Woodmaxx with side shift, but would consider other machines... will such a flail do all that I'm asking of it? Does anyone here have a Woodmaxx, or can you recommend another unit for less than $4000.
Thanks in advance for your help!
/ Let's talk flail mowers #3,235
I am afraid that your not going to be able to mow as little
as you want unless you invest in a flail crop shredder with
cup knives or side slicers and a higher horsepower mule.
Short of hiring it cut with a big high horsepower rotary
cutter/crop shredder you will have no ability to manage it
unless you move up into the 50+ HP class with a flail shredder
like a Vrismo orchard/vineyard shredder or a LandPride(Maschio brand)
orchard/vineyard shredder. The Land Pride/Maschio Orchard and Vineyard
flail shredder has the cast flail hammers and the rear trash door so you may
be able to manage doing it four times a year BUT NO flail shredder is going to handle
bowling ball sized rocks unless you have a landscape rake mounted under the tractor
or in front of it.
/ Let's talk flail mowers #3,236
I'm not mowing for looks etc. The infrequent mowing is because we are maintaining the land for honey bees. As the crop goes out of flower and to seed we will mow to distribute the seed/encourage growth, or for re-seeding/overseeding. I'm new to the property and some of it hasn't been mowed for 2-5 years and is 6ft deep in berry bramble, as well as small bushes/trees. I can knock this back with the rotary cutter no problem I don't like the windrows and want a finer chop on what I cut to get it to decompose quicker.
The rocks are a fact of life but will be dealt with over time. I was encouraged to look at a flail because of their use in roadside maintenance where they cut just a few times a year as well as deal with the associated junk that accumulates. I am not looking to mow rocks on purpose, but some fields just seem to grow them... frost water etc. brings them to the surface.
40 pto hp is what I have to work with... cup knives is what I am considering. I have looked at quite a few videos of fails dealing with very tall/tough vegetation. I have no problem going over the same area several times to get it knocked down, cutting it tall and then coming back a few days later to work it again to a shorter level/finer chop.
The rear trash door was one of the reasons I was looking at the woodmaxx unit with the forged cup flails. The landpride/maschio may be out of reach price wise... I'll look into it.
Thanks for the response, hopefully its more clear what I'm trying to do now. Feedback is appreciated.
Still interested in any feedback on the woodmaxx mower too.
/ Let's talk flail mowers #3,237
I have a ditch mowing contract in northern NM. I have mowed with side slicers on one flail (6' Virismo) and with duck-foot shaped flails (7' JD25A) and prefer the DF. I'm always hitting small limbs and trash and my maintenance time for blades is 90% less.
/ Let's talk flail mowers #3,238
Forward rotation (same direction as the tires) is safer as any rocks or debris will be thrown rearward. For the finest cut, reverse rotation and fine cut rotor is used. You almost never see a coarse cut flail with reverse rotation. Someone was questioning Mott's design and explanation. Mott invented the flail mower. There's so many more flails now because of how successful Mott's concept was. Their knives and many other aspects have been copied since original patents have expired. Many other types of flail knives/blades will plug up in heavy grass. Mott spent a lot of time figuring out the correct angle for the blades to be self cleaning and tested them in pig manure. There is a successful lawsuit initiated by Mott online of another company trying to copy Mott's knife design. When comparing flails I think you need compare apples to apples because there are flails for grass and weeds and there are flails for brush. Mott's design has stood the test of time.
/ Let's talk flail mowers #3,239
Well guys, I put the Sicma TE200 through a bit of a workout. Got 15 of 20 acres of 2' high clover small poplars and willow done in 6 1/2 hours. To say I'm impressed would be something of an understatement. I did manage to lose a couple of the shredding bars though. I'm going to have to come up with something better than the Cleve's pins I guessimage.jpegimage.jpeg
/ Let's talk flail mowers #3,240
I have one of the cheap Chinese 5' flail mowers and I would have no problem using it for what you're talking about but it would be very slow going. When I chop up a ~2" diameter tree I will raise the mower up, back over it until the top is in the mower, then pull forward and lower the mower to chop it up from the top down. That would take a long time with a big area of six foot deep brush.
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
CATERPILLAR 140 AWD MOTORGRADER (A63276)
CATERPILLAR 140...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
2008 Ford Edge Multipurpose Vehicle (MPV), VIN # 2FMDK36C08BA83160 (A61165)
2008 Ford Edge...
2005 Pequea Trailer Model 716 Deckover (A63116)
2005 Pequea...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
