To plow or not to plow
/ To plow or not to plow #1
budepps3760
Montgomery, Al
Mahindra 2810
I am confused. I have a disc harrow, box blade, bush hog and single row cultivator. I have been thinking that I need a moldboard plow and I will be ready to get started gardening. Seeing how I have never gardened before I wanted to read up and I watched a few videos on everything attachments. Read a few posts on TBN here and a few articles I found on Google. Watched a video or two on YouTube.
My confusion started when I read that plowing would not be a yearly event. That made me scratch my head because if it's not an implement used annually I could not see sinking that kind of money into something used so infrequently. Then I started reading that it was bad from a conservation stand point.
So my question is what is the truth? What would you recommend concerning tillage. I do not plan on a large garden, an acre or two at the most.
/ To plow or not to plow #2
A moldboard plow is execellent for opening new ground with a compact tractor. It should not be used annually. Moldboard plowing about once every eight years refreshes nutrients in crop root zone.
If you have a Disc Harrow which is heavy enough to cut the soil where you live that is usually enough to prep soil each year. A Disc Harrow with 9" spacing between the pans will cut better than a Disc Harrow with 7" or 7-1/2" spacing between pans, but leave a rougher bed behind the implement. A Disc Harrow with 7" or 7-1/2" spacing between the pans is meant to follow the plow. It will leave a smoother seed bed behind the implement. Monroe Tufline is well known for their Disc Harrows with 9" spacing between pans on the front, cutting gangs and 7-1/2" between pans on the rear, smoothing gangs.
(You can adjust aggressiveness of Box Frame Disc Harrow cut and bed smoothness by moving the gangs. The front gangs cut and should be set on a greater attack angle than the rear, smoothing gangs. It is evident from posts on TBN that a minority with Disc Harrows adjust them.)
If you want a smoother seed bed go over the disced ground with a chain harrow, spike tooth harrow or a Landscape Rake with gauge wheels. If the garden is small, a Ratchet Rake attachment for your FEL bucket works well.
For most Gardeners, a tractor PTO powered roto-tiller is an all-in-one garden implement, displacing the plow, disc harrow and chain harrow. Once operator is proficient, only a manual bow-rake is necessary before seeding.
It is important not to overwork soil with any implement. You can beat the life right out of soil, especially in hot climates where organic constituents break down rapidly.
To me, a one acre, irrigated garden is a huge commitment which will produce more vegetables and small fruit than a single family family can use. If your kids eat vegetables voluntarily they are unusual. A two acre garden is a commercial venture.
As always, above is generally true. For some situations, up North, with clay and gravel, plowing annually may be the the norm.
/ To plow or not to plow #3
I agree with everything in the above post. I pulled out what are, in my mind, the two highlights. We have a large garden, and the tiller is the key. Of course, it costs as much as a plow/disc/harrow combined...but does the job of all of them. From breaking new ground to garden in two passes:
/ To plow or not to plow #4
Agree with what they said. On virgin ground a moldboard will turn everything over and bury all the residue. After that is done you can just use a disc each year to prep it for planting. If you have ground that has grass or weeds growing thick on it and just have a disc it is going to take a lot of passes and time to get it to bare clean soil.
I bought a moldboard when I purchased 15 acres that was formerly in CRP grass. I tried my disc and it didn't work worth a darn. The moldboard buried it all and I just use the disc and a chisel plow each year now. I sold the moldboard as I don't need it anymore.
With just an acre I might just try discing it. It will take multiple passes but it isn't a large area. Just don't expect to start discing and then have a nice garden ready the next day. You will need to disc, let the plant matter break down and decay, disc some more, wait, disc some more, etc.
Thank you gentlemen for these enlightening responses. I have a much better idea of how now to proceed in the future. TBN is by far the best resource that I could have ever found.
/ To plow or not to plow #6
Better read up on canning too. :) A one acre garden, as already mentioned, CAN produce more than you eat or have room to store. Plan your rows and groups and stagger seeding (for the season) so you don't end up with 500lbs of cabbage all at once. :) My B.I.L. seeded about 10 rows by about 75' of Jalapeno peppers the first year as a trial run. His wife, my sister, was canning 4-8 quarts a week and giving away pecks of peppers. They ended up selling some of it from the parking lot of a local farm supply and turned some extra cash. The BIL had to have a hip replacement so this year his gardening chores are over and sister couldn't keep up. A garden is a lot of work and can add many hours to your schedule. Be sure to get everyone involved to spread the load. However, the reward can be a horn-of-plenty. Enjoy the fruits of your labor.
/ To plow or not to plow #7
What is the downside of using a moldboard plow every year? My current practice with my garden is to use the plow to turn over all the left over garden plants/stuff in October-November and let it sit over the winter. Come late April or early May I get the pto tiller out and hit it once and it's ready to plant.
/ To plow or not to plow #8
Plow Pan, a layer of soil compaction just below plowing depth, develops over years, inhibiting deeper root growth.
LINK: Google:plow Pan Layer
One should work the soil as much as necessary but no more than necessary. Especially in warm climate areas, such as the U.S. South, overworking will destroy organic material. Then the soil packs.
If your conditions require the plow, then plow. Try one year without the plow, just use the roto-tiller.
I read here on T-B-N that annual Fall plowing is still fairly common up north, in Michigan and Wisconsin, where the soil has considerable clay.
Further west, in the Great Plains, where wind erosion has to be seriously considered, Chisel plows are the norm, which are conservation plows. A light duty implement relative to a Chisel plow, for SECONDARY tillage, which performs the same function behind compact tractors, is the Field Cultivator.
Field Cultivators were among the first implements (mid-1930s) designed for the tractor Three Point Hitch.
/ To plow or not to plow #9
Chisel cultivators and disk's are nice but you have to have enough tractor to pull them properly.
The roto tiller would be the best choice but it too will leave a base layer as will a disk. The chisel tooth goes deeper and does break up the subsoil but to do that properly requires a bigger tractor.
/ To plow or not to plow #10
For a first time garden, i'd plow as deep as the tractor will pull one, size determines that. Here in TN with a lot of clay it packs pretty hard after a year or so.
I would plow in the spring & at the end of the season would "shallow" plow enough to turn residue back into the ground every other year. If i had a chisel, i would have used that instead. A tiller would be a great addition, all i had was a Troybilt tiller which worked great & provided me with plenty of exercise.
Thanks to the Mennonites only being 45 minutes away, it's cheaper to buy from them than raising my own.
Ronnie
/ To plow or not to plow #11
Another option is to move your 1 acre garden around in your 2 acres of ground, so about 2/3 of the garden area is fallow each year.
You can heap leaves, compost and animal litter on the fallow part and shallow cultivate it into the soil each Fall.
/ To plow or not to plow #12
get a tiller and a subsoiler or chisel and you will be set. Don't bother with the moldboard. If I could do it all over again, I would pick a spot, disc a few times the first garden season every few weeks or each month and let the seed bank reserves germinate and then kill with disturbance. One acre is a lot of ground to handle. If you get overwhelmed by weeds and let them go to seed, you are only making the problem worse for future years. I had to learn that the hard way. Its better to spray an out of control garden with glyphosate than to let the weeds go to seed. If you are going organic without any herbicides or synthetics, then do your research and good luck. I have been overrun with sicklepod and amaranth from the prior years mistakes. Don't take on more than you can handle.
/ To plow or not to plow #13
In your case, I would say not much. For many years we broke (plowed) corn and peanut land every year. With the invent of heavier tillage tools and higher hp tractors to pull them many have gotten away from every year. I have a lot of heavy clay so I still try to break most of my land every 5 years.
For the past few years, we have had problems with wild rye. One of the only things that you can do to control it in oats is break the land deep and bury the seeds. I have some fields that will be broke for the third year in a row.
The disadvantages are on a larger scale are the added cost and time.
/ To plow or not to plow #15
The 2 disc plow in the link below would be a good option and then use your disc harrow to prepare the final seedbed. For what it is worth a 1 or 2 acres plot is a "big" garden to me. I keep pretty busy on a 50 x 75 ft garden. Ken Sweet
Used 2 Disc Turning Plow 3 PT Hook We SHIP Fast and Cheap | eBay
/ To plow or not to plow #16
Biggest problem=erosion Soil gets broken down into finer particles and with no detritus on the surface it easily blows away.
/ To plow or not to plow #17
Hi :) If I can add my :2cents: ... The one downside of a mould-board plough I can readily think of is this - the very action of its operation:
If your topsoil is not deep enough, a mouldboard will lift some sub-soil, which has comparatively poor nutrient value and leave it on top of, or mixed with, your highly-nutritious topsoil or garden soil. This will notably reduce crop growth. :(
Farming practices of years gone by were similar to this - using such a plough (mould-board or deep-disc) in winter or early spring, leaving a few weeks, then planting a fodder crop for livestock. After several years, the land was almost useless - a perfect example is our block, as well as all our neighbours - all ex-farmland with zero goodness left, water-repellent, very, very hard when it's dry and struggles to grow any grass at all in places! :ashamed:
I would suggest to criss-cross it with a single-leg deep-ripper first, this will loosen it without mixing it up, letting air and water deep into it. Then, if necessary, same with a chisel plough (5 or 7 tyne), depends on the soil type and condition. I would certainly then use off-set discs as Jeff describes above. In subsequent years you may not need to deep-rip, and maybe chisel-plough and disc just once each ... rely on your judgement. :thumbsup:
My father lived on the land all his life and was a very astute and successful farmer. That was how we prepared many, many paddocks for planting - we were dairy farmers. He also understood the importance of regular use of fertiliser - although we rarely used lime - we apparrently didn't have a soil ph problem, we frequently spread superphosphate (to add phosphate) and nitram (for nitrogen-enrichment). I would love to know how many hundred tons of this I have spread whilst growing up - almost all of it with the MF135 we now have here! However he would not ever use a roto-tiller (we know them over here as a rotary-hoe). We never, ever owned one. I don't know why, but I guess he knew more about agriculture than I'll ever know!:laughing:
Hope this helps somehow; and may all your fruit and veggies grow high & huge! :D
/ To plow or not to plow #18
You have plans for a one-acre garden, wow. I have a garden - 80 x 120 = about 1/5 of an acre and it produces enough to feed three families. Just the thought of a one-acre garden makes my poor back ache - weeds.
I've tried opening virgin land with just a disk harrow and its very difficult & time consuming. I even put a 400# block of concrete on the disk harrow and it only cut marginally deeper. I ended up buying and using a single bottom moldboard plow. By turning the soil only 6" to 8" deep, the disk harrow then did an excellent job.
However, if you are serious about a one-acre garden then I would forget the moldboard plow/disk harrow and purchase a pto driven rototiller. Its definitely an all-in-one implement. It will be used annually to prepare the site for planting and in the fall to combine the soil/crop residue.
Based on all the comments about the size of a garden I am definitely reducing the size.
/ To plow or not to plow #20
Unless you have a lot of "willing" helpers to weed its a lot easier to start smaller and then increase if you see the need, in the following years. The first year my garden was BIG - 100 x 150. We blanched and put up 65 quarts of cut corn, 85 quarts of zucchini and had untold sacks of spuds down in the basement. We got so tired of weeding & picking that after we had put up 45 quarts of frozen green beans the wife begged me to till them under. That was 34 years ago and I still have nightmares of crawling around on my knees - weeding.
2017 Case CX145D (A60462)
2017 Case CX145D...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
CASE 610 Sprayer System 2000 Gallons (A61307)
CASE 610 Sprayer...
2016 Lawnhorn Utility Trailer (A60352)
2016 Lawnhorn...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
