Building stairs/steps
/ Building stairs/steps #1
dieselcrawler
Elite Member
Lucasville Ohio
2013 JD 3005 2001 Kubota BX1800
I'm going to be replacing a flight of steps at one of my rentals, a garage/apartment... the stairs going to the apartment are on the verge of catastrophic failure.
No real issues, remove the old ones, replace them with new ones... have most of the material already on hand, need to buy a box of 3" deck screws, and just do it. I have already cut out the stringers, (did that this evening) I have changed the pitch a little, stretching them out a little, to make them not so steep.
I've built meny sets of stairs over the last 20+ years, the math involved comes easy to me, and having built one set in particular that was just perfect, very comfortable rise and run ratio, easy to walk up one step at a time, or double step them if you want...
Who else likes to build steps/stairs?
/ Building stairs/steps #2
They are a satisfying project for sure, although I am finding that in their use, going down is much easier on my knee's :laughing:
/ Building stairs/steps #3
rise and run sums to 18, the stair will be comfortable.
Don't forget the tread thickness in the layout!
/ Building stairs/steps #4
I like doing them. Wanting to do a square spiral off my 2nd story deck one day. Project list has a ways to go to that one though.
/ Building stairs/steps #5
I no longer enjoy it because some of the property I have looked after for since the 80's and wood steps need maintenance... it is just a question of time.
For small walk-ups I pour concrete... for larger staircases I have a buddy that installs precast concrete apartment/commercial style and so far they have been 100% maintenance free.
/ Building stairs/steps #6
I've only built one set of stairs in my life, for our deck, about 7 steps. I read up on it quite a bit, measured twice, cut once and it turned out perfect. I don't want to push my luck an further!!! :laughing:
But it is very satisfying, indeed. :thumbsup:
/ Building stairs/steps #7
Stairs, finish carpentry and oddly enough roof framing were always some of my favorite tasks when I was remodeling for a living. I was/am a math geek and to me math + trades work = fun.
Weird I know but there it is.
/ Building stairs/steps #9
I'm not a fan. It makes my head hurt trying to figure it out. I go to this site to do the math for me. Stair Calculator - Plan Diagrams
One of my pet peaves is a stairway without a center stringer. Most seem to be two stringers 26 inches apart with a pair of 2x6's spanning that distance for the step. I treat stringers like floor joists and never go farther then 24 inches. I can't think of a set that I've ever done that didn't have at least three stringers.
Back in CA, where I'm from, a friend's family owns a bunch of apartment buildings. They had a person trip and fall on their stairs and they where sued because there was more then a quarter inch difference in the stair height. When they went and measured, they found that just about every set of stairs in all their buildings where off a little. The lawsuit cost them a fair amount, taking out all their wood stairs and putting in metal ones cost a fortune!!!!
When I build a deck, I like to make the bottom step concrete and then attach my stringers to the concrete. Makes it easy for mowing and you never have any rot issues.
/ Building stairs/steps #10
I was going to mention the liability part of stairs and rentals... this is why I have converted to precast concrete with metal stringers...
Railings are another big issue.
/ Building stairs/steps #11
I
Terry
I'm in total agreement with you... I also equally enjoy roof framing.
/ Building stairs/steps #13
26 inch centers is too much? did you calculate the live load on that? ;-)))
/ Building stairs/steps #14
Math skills are a must when it comes to some of the finer points of carpentry...IMO> Applying math is the easiest way for those that it does not come naturally to understand it...some of us are lucky enough where if comes easily...
I've built half a dozen or so (residential) circular staircases and more typical stairs than I can remember...
One of the easiest ways for a DYI'er to build a curved etc.staircase is (after the math is done) building each riser individually...it takes a bit more material than some other methods...each riser built like a partition out of 2x10/12...(progressively getting taller) secured and plumbed to a radius is easily finished in many different ways...
/ Building stairs/steps #15
Like stair cases...hip roofs are fun to cut all the rafters for...if you have good measurements/accurate drawings etc. (and can read the rafter tables)...you can cut every common,hip,valley and jack rafter from just a few measurements...great satisfaction...!
/ Building stairs/steps #16
Makes me giddy in fact :)
IMO there is little to compare with the satisfaction of being able to cut a roof after taking a site level to the foundation and verifying the measurements, do all cuts before nailing the first one. :) Fun times.
/ Building stairs/steps #17
Sorry, I meant to type 24 inches, not 26. I was using my phone to reply.
/ Building stairs/steps #18
I have built several stair units around the house. Mainly for the deck but I did just build these. They are for the garage to house entrance.
I had the plywood laying around the garage but the steps are the 5/4's pine from Home Depot. Nice wood for 9 bucks each.
Trying to get motivated, and get the wife and kids schedules figured out... (wife needs to get some shopping done, oldest boy works at the municipal swimming pool later today, 8 of us dont fit in my ext cab truck, have to take 2 vehicles, main road to town closed, have to go back roads around, etc) hope to get this project done today.
I'll try to get some pictures as things progress.
/ Building stairs/steps #20
Just read this again and realized I still got it wrong. I see a lot of stringers 36 inches apart without a center stringer. I feel that is too far apart to properly support the steps and anything wider then 24 inches should have three stringers.
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
53ft Reefer Trailer, VIN # 1GRAA06267S701883 (A65563)
53ft Reefer...
Adams 5 T Fertilizer Spreader (A63689)
Adams 5 T...
2004 Mack CH613 Concrete/ Water Mixer Truck (A64194)
2004 Mack CH613...
