Farmtrac 535 how to check hyd. fluid?
/ Farmtrac 535 how to check hyd. fluid? #1
grandpawj
Member
Lancing, TN
Farmtrac 535 W/ 5245 front end loader(turf tires), MFG 2006
I know it should be intuitively obvious but I am not quite sure how to check the hydrolic (I know I can't spell it) fluid. I lost some when working on my loader and need to see how much to put back in.
/ Farmtrac 535 how to check hyd. fluid? #2
On my 675 there is a dipstick behind the seat just up and right of the pto output shaft.
/ Farmtrac 535 how to check hyd. fluid? #3
On my 555 there is a plug by my right foot while sitting on it. You add fluid where the previous poster said his dip stick is. Add fluid until it comes out the hole.
I will check tomorrow. It's 10 p.m. right now. However, I do remember that my return for the Hyd fluid is right behind the seat where one would expect the dipstick to be. I am sure I will have to remove it to add fluid. Most likely I will see the plug you are referring to in the morning. Thanks for both your replies.
Yep Clint, that's where mine is too. Thanks.
/ Farmtrac 535 how to check hyd. fluid? #6
To make life easier I will just use a little hand pump and pump fluid into that hole, especially if the back hoe is on
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
For Sale L4479 Snowblower and Subframe
For Sale L4479...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
IRANCH Auger Mini Skid Steer Attachment (A59228)
IRANCH Auger Mini...
