Farmtrac 535 how to check hyd. fluid?
   / Farmtrac 535 how to check hyd. fluid? #1
grandpawj
Lancing, TN
Farmtrac 535 W/ 5245 front end loader(turf tires), MFG 2006
I know it should be intuitively obvious but I am not quite sure how to check the hydrolic (I know I can't spell it) fluid. I lost some when working on my loader and need to see how much to put back in.
   / Farmtrac 535 how to check hyd. fluid? #2
On my 675 there is a dipstick behind the seat just up and right of the pto output shaft.
   / Farmtrac 535 how to check hyd. fluid? #3
On my 555 there is a plug by my right foot while sitting on it. You add fluid where the previous poster said his dip stick is. Add fluid until it comes out the hole.
I will check tomorrow. It's 10 p.m. right now. However, I do remember that my return for the Hyd fluid is right behind the seat where one would expect the dipstick to be. I am sure I will have to remove it to add fluid. Most likely I will see the plug you are referring to in the morning. Thanks for both your replies.
Yep Clint, that's where mine is too. Thanks.
   / Farmtrac 535 how to check hyd. fluid? #6
To make life easier I will just use a little hand pump and pump fluid into that hole, especially if the back hoe is on
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
Galvanized steel fence (A53424)
Galvanized steel...
2005 John Deere 310G 4x4 Loader Backhoe (A53421)
2005 John Deere...
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A53421)
2025 SDLL30 Mini...
