L4200 block heater.
/ L4200 block heater. #1
Luath
Member
Canada
Kubota L4200
Hi Guys,
I've discovered an old block heater (no cables) on the tractor and as I'm taking the machine to Manitoba I felt it would be prudent to replace it. The hex nut is some 28mm and the replacement is 17 mm. Is there liable to be a problem with the actual fitting? I assume it's best to replace but I did wonder about leaving the old heater and using a new cable (if it fits) but I was unsure as to how to test the heater. Do I need to drain anything before removing the heater. The heater is located in a frost plug? at the level of the starter motor and the oil filler cap.
Any advice gratefully received.
Dave.
/ L4200 block heater. #2
Plug it in to a gfci outlet with a good breaker & see if either pops. If not, come back in 20 minutes & see if things are warm.
If breakers & gfci don't pop & it puts out heat, why change it?
Hi Fallon,
Pardon my ignorance, I'm from the UK and I'm not familiar with the meaning of gfci outlet. Perhaps a word of explanation?
Many thanks,
Dave.
/ L4200 block heater. #5
Or, stick a volt-ohm meter across its terminals. An open circuit- no voltage flow, means... it's shot. Some resistance is good. No resistance to voltage flow means it's shorted out- shot. At least I think that's correct. Maybe someone with more experience will offer better advice?
/ L4200 block heater. #6
Pretty much. How to test water heater element talks about water heaters, but is otherwise right on. A block heater will be much lower wattage, so have a much higher resistance. Maybe a couple hundred ohms id guess.
Somebody else already answered the GFCI... Safety device to prevent current leaking to ground, required on all outside & potentially wet locations by US code. Id imagine the UK is similar. Its been a couple decades since I lived there though. Not strictly required, but a good idea.
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
John Deere 6110M (A60462)
John Deere 6110M...
