New EA Land Plane(LPGS)
/ New EA Land Plane(LPGS) #21
I'm pretty sure I'd NEED the rippers. By the pictures, the Road Boss appears useful on gravel but I don't have gravel. I need to break up the top layer of clay and spread it even. That's where the rippers would be beneficial, I think. If I can back-drag a 2,000+ pound dozer blade over it and not break the top layer, a couple of angle iron bars won't hack it. I appreciate the response though as it has some important information to consider.
/ New EA Land Plane(LPGS) #22
I just had a light go on! :) What if made flat plate skids for the sides of the dozer blade? (Similar but larger than that used on snow blades.) This might control dig in. The problem is my blade doesn't angle--Yet. I've got two 4" cylinders for the task and there's already an unused control valve on the dozer. I just need to make the angle coupling for the blade.
/ New EA Land Plane(LPGS) #23
I sort of doubt that your dozer blade is 2000lbs from the looks of it. Also you are dragging backwards, the LPGS would be cutting into the ground, not using the back edge of the cutting edge like you are with the dozer. I have a dozer also, trust me when I tell you that the LPGS is far better for road maintenance.
As far as putting edges on your dozer blade, yes it will help, but it's no LPGS, plus I thought you wanted to use a wheel tractor?
Good luck with your decisions. ;)
The new Land Shark Land Plane is now live on our website, complete with introductory prices and a video with Ted.
Free Shipping to a staffed commercial business or supporting freight terminal within 1,000 miles of Newton, NC.
There is also a special offer, so check it out!
Travis
/ New EA Land Plane(LPGS) #25
Judging by that picture, money would be better spent on some new pads!
/ New EA Land Plane(LPGS) #26
Why? The pads work fine for farm duty. And the "street cleats" don't damage the yard while traversing and they're great for packing the driveway. It's a 1956 pipe layer and is not entered in any shows. At my age, the next custodian can replace the pads. :thumbdown:
John Deere XUV825E (A61307)
John Deere XUV825E...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
2022 SANY SY35U EXCAVATOR (A63276)
2022 SANY SY35U...
UNVERFERTH H25 - 25' HEAD CART (A64277)
UNVERFERTH H25 -...
INOP/NON - RUNNING 1997 Procraft Fish/Ski Boat (A65579)
INOP/NON - RUNNING...
STIHL HT103 POLE SAW (A62613)
STIHL HT103 POLE...
