Kioti DK35
/ Kioti DK35 #1
3gGT01
Bastrop, TX
Kioti DK35
Hi Folks!
I have a DK35 and have put exactly 200 hours on it. The IP middle gear broke some teeth. The tractor has been down since Sept. 2015. At that time I got as far as figuring out the IP rack was hanging and it wouldn't start unless I moved the rack over towards the right. I went on vacation and just never fixed it. I'm finally at the point where I have to have it running, so here I am. I ordered 3 new gears from Conestoga Diesel Injection, but I believe I have the plungers turned 180 degrees from where they should be. The tractor engine is running wide open. I will check the plungers tomorrow and likely rotate them 180 degrees and test it out again.
~Tom
/ Kioti DK35 #2
G'day Mate and welcome to TBN from Downunder.
Enjoy the site and good luck with your repair.
/ Kioti DK35
Thanks Wagtail! Kind of neat to hear you are from Tasmania!
~Tom
/ Kioti DK35
Good news, I rotated the IP plungers 180 degrees and the tractor is working great. With the IP slides/roller stop pins facing upward, the plunger slots must face to the left with the slide rail in the middle of its travel.
~Tom
/ Kioti DK35 #6
~Tom
Welcome to TBN Tom, with your mechanical knowledge we can sure use you on the Kioti forum.:thumbsup::)
/ Kioti DK35
Thanks Murph! Wow, 19,940 post by you. Holy cow, that's a bunch. :thumbsup:
/ Kioti DK35 #10
Do you know what year your tractor is ?
Is it a DK 35SE model ?
Just curious, because so far it seems to be only certain years (2005-2008) that have had the IP issues.
Glad to hear you got it going.
/ Kioti DK35
Hi DK35vince,
It's not the DK35SE, it is just a plain old DK35. I know for sure that the tractor was build between 2005-2008, but not 100% sure yet on the exact year. The tractor had 627 hours on it when the IP middle gear broke some teeth. I'll check the frame S/N and let you know.
It was really great to have the tractor running again today, especially since I needed to unload the trailer with 10,237 lbs worth of Paver retaining wall blocks today. I need to pick up the other pallets from Home Depot tomorrow, before they decide to ship them back. You have 7 days to pickup special orders, but they will work with you, if you let them know you can't pick them up within the 7 day period.
~Tom
/ Kioti DK35 #13
Not much to do when your stuck in bed.
/ Kioti DK35
Oh, sorry to hear that Murph! I only hope that is temporary.
~Tom
/ Kioti DK35 #15
~Tom
It was awhile ago and I'm much better, thank you.
/ Kioti DK35
My SN starts with 'E', so my understanding is that it was manufactured in 2005.
~Tom
2015 COTTRELL CAR HAULER (A67714)
2015 COTTRELL CAR...
(INOP) 2005 CATERPILLAR 535B SKIDDER (A65056)
(INOP) 2005...
2018 GENERAC MOBILE PRODUCTS MLT6S (A67714)
2018 GENERAC...
2016 Mazda Mazda 6 Sedan (A66738)
2016 Mazda Mazda 6...
2018 CATERPILLAR D11T HIGH TRACK CRAWLER DOZER (A65056)
2018 CATERPILLAR...
2006 FREIGHTLINER CST120 STAND UP SLEEPER (A67714)
2006 FREIGHTLINER...
