Kioti DK35
/ Kioti DK35 #1
3gGT01
Bastrop, TX
Kioti DK35
Hi Folks!
I have a DK35 and have put exactly 200 hours on it. The IP middle gear broke some teeth. The tractor has been down since Sept. 2015. At that time I got as far as figuring out the IP rack was hanging and it wouldn't start unless I moved the rack over towards the right. I went on vacation and just never fixed it. I'm finally at the point where I have to have it running, so here I am. I ordered 3 new gears from Conestoga Diesel Injection, but I believe I have the plungers turned 180 degrees from where they should be. The tractor engine is running wide open. I will check the plungers tomorrow and likely rotate them 180 degrees and test it out again.
~Tom
/ Kioti DK35
Thanks Wagtail! Kind of neat to hear you are from Tasmania!
~Tom
/ Kioti DK35
Good news, I rotated the IP plungers 180 degrees and the tractor is working great. With the IP slides/roller stop pins facing upward, the plunger slots must face to the left with the slide rail in the middle of its travel.
~Tom
/ Kioti DK35 #6
~Tom
Welcome to TBN Tom, with your mechanical knowledge we can sure use you on the Kioti forum.:thumbsup::)
/ Kioti DK35
Thanks Murph! Wow, 19,940 post by you. Holy cow, that's a bunch. :thumbsup:
/ Kioti DK35 #10
Do you know what year your tractor is ?
Is it a DK 35SE model ?
Just curious, because so far it seems to be only certain years (2005-2008) that have had the IP issues.
Glad to hear you got it going.
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
Giyi Mini QA Auger (A60463)
Giyi Mini QA Auger...
BOBCAT T190 (A60736)
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
Komatsu HM400 (A60462)
Pallet Shelving (A60463)
Pallet Shelving...
