Newbie
/ Newbie #1
mahindraweary
Member
Lissie, Texas
2014 Mahindra 4025 4WD
At73 years of age I wanted to see if it felt any better to refer to myself as a newbie. It doesn't. Anyhow, I am 73, I would have been 74 but I was sick a year. I have a 2014 Mahindra 4025 4WD and I have a love hate relationship with it. When it starts, which is rarely, I can get my work done in no time. But, many times I go out to get some work done here on the farm and it just won't start. Doesn't click or anything. So, I call myself Mahindraweary (My name is JC Cooper). I had a Ford 3000 for 40+ years and I didn't have as much trouble with it as I've had with this New Mahindra in just 18 months.
Glad to be here and looking forward to learning something. But hurry, I don't have long left.
JC
/ Newbie #2
Hi. Welcome. Lots of help here.
Sounds like you may have a loose wire causing the starter issues. Check ground wires as well.
/ Newbie #3
JC
So if the engine does not crank, which I believe you are describing, what have to done so far to diagnose this problem.?
Do you own and understand how to use a voltmeter? Do you have an understanding of Ohm's law? Do you have an understanding of the scientific method as it relates to troubleshooting problems? As an example, "is the problem this way or that way in the circuit". How to cut the problem in half and exclude that half and continue troubleshooting the suspect half?
Let us know how you would like to proceed after answering these questions.
/ Newbie
Yes, I own a volt/ohm meter but I've probably forgotten almost everything I knew. I'm going to start at the battery and put the red on the + and the black on the frame to see if I am getting the full 12 volts. Then I'm going to go to the starter and do the same thing and just trace whatever I can. What I have done so far, outside of cussing a lot, is to try (emphasis on try) to find all the safety switches. I think I found two, the pto being the only one I could get to so far, and it was plugged in tight. Other than that, I'm stumped.
Should I move this to the Mahindra forum? Thanks for your response. I do appreciate it.
/ Newbie #5
Welcome to the forum, JC.
:welcome:
I'm going to move your thread over to the Mahindra section. It sounds like you might be spending some time in it.
/ Newbie #7
welcome! not much help but a stupid question - how are your terminals ends connected to the battery. i have seen others here have some corrosion issues and i have cleaned mine a few times but when it went in for service i asked about this and possible under warranty - not sure yet about warranty but the head service guy said they were shot and not showing a full load on crank so he put new ones on. I never noticed an issues starting - but did notice rust really bad. so maybe????? i do not have meters and experienced no issues - but the guy had equipment and said there was some problems so figured I'd mention that - i also find it weird it would corrode in 1 1/2 yrs of owning it....
/ Newbie
Thanks for the welcomes. I cleaned the battery terminals today. Didn't help. I'm moving over to the Mahindra forum so maybe I'll catch you there.
I was in Vietnam with an Aussie detachment. Those guys were a real hoot.
/ Newbie #9
Check and clean the other end of the cables where they connect to the starter and Tractor
/ Newbie
I've got a heavy work schedule next week so it will be Friday before I can get back to the tractor but I intend to clean every connection I can find. Tks Old Pilgram
JC Cooper
56th Air Commando Wing
66-68
/ Newbie #11
Hi and welcome to TBN. More importantly, thank you for your service to your country! God bless you and all who have served, do serve and will serve.
Intermittent issues can be difficult to diagnose, but the good news is that 9 times out of 10, it's a simple fix.
Start with the obvious (Loose wires, poor connections), then test the safety switches. Also check the ignition switch. I seem to remember reading that some models had issues with their ignition switch and water (?).
Good luck and let us know how you solved your problem.
/ Newbie #12
You need a helper. One person on the seat, making an attempt to crank the engine, the other person reading the volt meter. start by placing the leads directly on the battery terminals. Have the helper attempt to crank the engine, read the battery voltage with this load on the battery. If this appears correct, move the leads out to the battery terminal clamps and read it there. This will determine if the clamps have a high resistance connection to the terminals. Move on out to the starter bolt and frame of the tractor and repeat attempt to crank. This will show if there is a high resistance (corrosion) in the battery cables. Lets end there for now, and report back.
/ Newbie #13
JC
JC, you are funny with words. When you get your tractor fixed, you need to stick around here. You will chase this down and fix it. The 4025 is a simple and reliable machine. You must either have a bad connection or a bad safety switch. If neither, then maybe a ignition switch or a problem at the starter, but that is unlikely. Seems you are getting good advice. Best of luck.
The tough electrical problems are the occasional intermittent type. Seems yours has passed that point and that actually makes it easier to chase down.
/ Newbie #14
Dave is there any way you can post the electrical schematic for his tractor? I don't have one.
/ Newbie #16
I don't have a handy way to do that. it's a pretty simple system.
Well, is there the typical start relay and is it wired from the key thru the various safety switches that controls the current for the starter solenoid?
/ Newbie #18
pull the pto lever back.. remove the brass cover over the pto switch.. then push the lever back forward first to be sure its hitting the switch. if so then press it in manually and see if it clicks...
/ Newbie #19
the one on the high/low just screws into the side of the shifter housing its very easy to get out..
/ Newbie #20
One simple way to help determine if it is likely safety switch or start relay problems is turn on the tractors headlights. Now observe these lights carefully as the assistant attempts to start the tractor. If the lights dim a bunch or even go out, then the corroded cable, corroded connections or just defective battery are likely culprits. If the lights stay near full brightness as the tractor is attempted to crank, then it is not likely a battery/cable/connector problem and much more likely is the key switch or one of the many safety switches in series with the coil of the start relay or the start relay itself being defective.
New/Unused Top Cat Quick Attach Stump Grinder (A61166)
New/Unused Top Cat...
1999 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61568)
1999 Fontaine...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
