BX mower blade replacement (double check)
/ BX mower blade replacement (double check) #1
buckeyepost
central Ohio
/ BX mower blade replacement (double check) #2
Get under the deck.... turn the blades so you can measure the Exact clearance between the blades at their Closest... I will bet you have a LOT more than the quarter inch... KennyV
/ BX mower blade replacement (double check) #3
How did you measure the old blade? Should be from corner to corner across. Also if it's been sharpened enough the measurement will decrease.
Someone else just told me that they are measured diagonally, I never knew that... seems kinda stupid really.
/ BX mower blade replacement (double check) #5
You have to think of the blade moving in a circle. The cutting tips will be outside the diameter of the blades measured directly across the blade.
/ BX mower blade replacement (double check) #6
Not really, if you think about how the blade travels then it makes sense as the corner of the blade is going to travel at a larger radius then the center of the squared off end. The diagonal measurement represents the active cutting length of the blade.
I have comercial mowers that have have 2 blade options, one is 2.5in wide, the other is 3in (HD version). In order to maintain the correct cutting width the length straight across the blade must be decreased.
2004 IH 5600I Snow Plow Truck (A62679)
2004 IH 5600I Snow...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
4004SFL (A59228)
4004SFL (A59228)
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2844 (A58376)
2844 (A58376)
