Draft / Depth Control on 2012 Mahindra 4025 2WD
   / Draft / Depth Control on 2012 Mahindra 4025 2WD #1
zachp
Madison
Mahindra 4025 2wd
Forum
I am new to plowing ....and tractors
Hooked up the plow to my 3pt , but I cannot get the plow to break into the ground. I have Position Control on lowest and Draft Control deepest setting. The plow just appears to float on the ground.
Any advice ?
Thanks
Zach
   / Draft / Depth Control on 2012 Mahindra 4025 2WD #2
Send a picture, let us see what you have got. Most likely something simple. I have a 4025 2wd and my middle buster will really dig deep quickly.
   / Draft / Depth Control on 2012 Mahindra 4025 2WD #3
Welcome aboard, you will be able to access a huge amount of information here from some owners with years of experience. All kinds of tips and tricks and shortcuts.
Thank you Bursynr:
I do not have a picture with me , but can get one later in the week. A description until then:
I have:
1) adjustable lift links on both sides.
2) Stabiliser bars on both sides
3) When I attempt to plow or scrape , the DC level is fully forward (ie Deepest) , the PC lever is fully forward ( is Lowest) and the draft control valve ( under the seat in front of the driver) is fully open and locked. I do not mess with the draft control valve since I understand it is only to be used when transporting the tractor.
The manual says that i need to have the adjustable lift links in the fixed position -- and for the life of me , I cannot figure out what that means.
it just appears that the tractor is not pushing the 3Pt system down far enough and keeping it there ... it appears to float ..
I'll get pictures some time this week ...
thanks in advance for any advice.
P.
   / Draft / Depth Control on 2012 Mahindra 4025 2WD #5
Are your Stabilizer bars pinned on both sides? Is the center link adjusted to put the plow at the proper angle to get a bite on the ground"? Is the PC stop nut all the way to the bottom? If it is a single or double bottom plow it should be heavy enough to get a bite on the ground and pull down. If it is a middle buster, I have seen pictures of the sweep being mounted upside down.
   / Draft / Depth Control on 2012 Mahindra 4025 2WD #6
3pt or 'Rock Shaft" is usually gravity drop. No down pressure. I'm guessing you don't have your center link adjusted correctly. :confused3:
Thank you -- I cannot recall and will go check. By pinned I assume you mean that it is pinned in a single slot so that it cannot move.
P.
Thanks Jabonee. I'll make sure that the center ( ie top link ?) is adjusted so that the angle of the implement is conducive to ground penetration ... and that the lift links are as extended long as possible.
P.
   / Draft / Depth Control on 2012 Mahindra 4025 2WD #9
Did you get it figured out?
   / Draft / Depth Control on 2012 Mahindra 4025 2WD #10
You need weight! hard to bust unworked ground with 3point implements
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2019 CATERPILLAR 299D2 SKID STEER (A51242)
2019 CATERPILLAR...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
Heavy Haul trailer (A49461)
Heavy Haul trailer...
