Pallets in fields
   / Pallets in fields #2,582
I don't mess with Texas and stay out of Florida when the swamps are on fire.:confused3:
   / Pallets in fields #2,583
Well I've solved the mystery. I stopped and asked a farmer why he had pallets stacked in the inverted V shape in his field. He said he had an old well under the pallets and he didn't want to hit the well we he cut hay in the field.
I made the above statement up but it would explain it or some other similar thing.
   / Pallets in fields #2,584
Obviously.
Since the initial observation of inverted V pallets was reported, those who have ventured to question the landowners have NEVER RETURNED (to provide the answer)! There was a case in Washington State, with photographic & aerial confirmation... the correspondent was not able to follow-up his dispatch.
Apparently, one does not simply walk in to an inverted-V pallet patch.
   / Pallets in fields #2,585
Obviously.
I tried, but couldn't get close. There appears to be some sort of field preventing access.
If you look on Google Earth and use the timeline, you can see how the field changes over the years, with various regular and irregular patterns.
N 46.47756 W 122.94759
It is probably some kind of signaling system for the interplanetary pallet ships.
Bruce
   / Pallets in fields #2,586
Obviously.
Hmmmm-
similar to....
Mordor??
   / Pallets in fields #2,587
I saw this load headed east...
   / Pallets in fields #2,588
I believe that we covered the scientific discipline of Palletology back in 2014...
It is obvious that this gentleman is working on his BS degree in Palletology. BUT - he will never achieve his doctorate degree at the rate he is going.
It is my belief that he has been captured by Captive Pallets. Obviously, it was a terrific fight.
   / Pallets in fields #2,590
Well, forklifts have tines, so this is a designated spy spot for Senator Palletine.
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
2017 KALMAR OTTAWA T2 4X2 SPOT TRUCK (A60430)
2017 KALMAR OTTAWA...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
bad boy zero turn 72 (A56859)
bad boy zero turn...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
