What attachment should I use?
/ What attachment should I use? #1
jodebg
New Hartford, CT
Kubota B-2650
I have a 2 year old sand access road that I maintain. Weeds are beginning to
take over and I would like to clear them out, as best as possible. What attachment
would be best to use to pull out as many weeds as possible?
/ What attachment should I use? #3
Yep, RoundUp is the best attachment for this. If the weeds are really thick and tall, I'd sparay and perhaps followup with a York rake in a week or so.
/ What attachment should I use? #5
Another endorsement of glyphosate. I have noticed that prices for 41% glyphosate (2.5 gallon) are down this year in my area.
Steve
/ What attachment should I use? #6
Three thumbs up for glyphosate! (thought I'd chime in with an 'international' endorsement) It'll get the broad-leaf plants & grasses... however if you've also got bracken or 'woody' stemmed weeds you'll either have to pull/dig them out or spray them with something a bit more robust.
What is the way to purchase glyphosate? I see both 41 and 70% available. And many brands available. Will this herbicide also kill poison ivy?
/ What attachment should I use? #8
So many farmers in my area are using Roundup resistant crops the weeds are getting harder to kill, so we are often using Crossbow, Trimec or Cimmaron on broad leafs. We still use Roundup Ultra, but it seems we are applying it more frequently. Try Roundup and if it doesn't do it, check with your neighbors or local extension office.
/ What attachment should I use? #11
It's easy to find the 41% for about $40 for 2.5 gal jug. (It get's mixed way down with water) That's what I use, and it will even kill Beech.
Do you have Tractor supply (TSC) around in CT?
/ What attachment should I use? #12
I'd go for a sterilant such as Sahara or Mojave as long as runoff isn't an issue. RoundUp doesn't prevent new growth.
What are the environmental issues relating to these products?
/ What attachment should I use? #14
Here is the link for the label: http://www.cdms.net/ldat/ld545000.pdf
Not sure what you are looking for John but I'll tell you what I know from my experience. We are careful to use this (I run a lawn and landscape company) where runoff can be an issue. I would expect a sandy base driveway would not run off into the lawn. Large industrial parking lots that are weed free typically were treated economically with a sterilant. Both these products are granular and can be mixed in a backpack or boom sprayer or another option is to spread the granules on the ground where they collect by cracks in the pavement and prevent the weed growth. We seldom treat areas more than once a year when using this product. I plan on spraying a fenceline this weekend after weedeating it down thoroughly. I will only use this type product if I know rain is not in the forecast for a few days so the product soaks into the soil and doesn't have the chance to run off and kill downhill grass and vegetation. You can buy the homeowner version of this product at Rural King/TSC, etc.
/ What attachment should I use? #15
I use the glyphosate from TSC, and it works like a charm. You have one close to you in Barkhamsted. Good luck!!!!
Thanks to everyone for all the helpful information. Will be making an application soon.
/ What attachment should I use? #17
One more point about glyphosate: Roundup's patent expired. The generics are the same thing.
But read the label - Roundup is sold in 41% and 50% concentrations plus a weaker concentrate for the home gardener. Also a thinned version in a spray bottle for direct application. Generic brands should work as well but might be other concentrations. You need to know the concentration being sold, to compare price per gallon of working mix.
Good points...thanks.
/ What attachment should I use? #19
The generics can differ according to whether they contain a surfactant and the type of surfactant they use. Based on my limited experience, adding dish detergent as a surfactant to glyphosate packaged without a surfactant isn't as effective as adding a commercial surfactant. Commercial surfactants aren't cheap, so I think buying glyphosate with surfactant already added is usually more cost effective.
Steve
/ What attachment should I use? #20
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Bulk Lot - Used Steel Transfer Pipe & Fittings (Chuck Pipe) (A63689)
Bulk Lot - Used...
Lonestar Panel 24ft. Free Standing Panel with Feed Bunk (A65640)
Lonestar Panel...
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
