CK30 Auto Shut Off
/ CK30 Auto Shut Off #1
1965
Trenton Ontario Canada
2008 Kioti CK 30
I have found that when I turn to the left to look at the rear of my CK 30 my right knee tends to hit the key just in the right spot to shut it down. I have a rocker HST foot pedal so I have the seat up a bit to be comfortable on the pedal....short legs:). I am thinking of putting a shield on the right side of the key or even cutting the key down to make it less of a target. Anyone else tackle this minor issue?
/ CK30 Auto Shut Off #2
I broke one of the original keys on my CK35 after about the third time I hit it with my knee and then straightened it up. :(
The location of the key is really my only complaint about the tractor - it's a simple design issue that could have been done better.
I used the spare key to get a copy cut and then ground down the copy so as to leave only a small (half inch) "lever" to turn the key. I place the key in the lock so that this lever is vertical.
It seems to be working because I haven't hit it hard enough yet to bend it - or gouge a hole in my knee.:laughing:
/ CK30 Auto Shut Off #3
I've done the same thing many times on my CK 25. It is in a bad spot. I think thats a good idea to shave/cut the key. I'm gonna do that to mine now that you mention it. I'm gonna try to keep the end soft so I dont puncture my knee. If not done right, it could make it worse. But then again, a new key isnt gonna break the bank so I wouldnt be afraid to experiment with it.
/ CK30 Auto Shut Off #4
My father is about a half a foot taller than me & he has done this as well (haven't broken the key yet)
I like your solution & it reminded me that Dad had a motorcycle that the hard side saddle bags required you to put the key in to open every time. This can sometimes be a major PITA so he had 2 keys made, cut the heads down and used knurled knobs (the kind designed to be held on w/ a set screw) and cut a slot in them for the key shaft to fit in & tightened the set screw.
He then just put one in each lock and left it there. I may have to do this w/ a tractor key.
I like the idea of adding a knob type thingamajig to it, less likely to turn it off. I am going to get a couple copies made rather than use my originals and find/make a dome shaped knob and epoxy that to the key so my knee will just glance off rather than turn or dig in.
/ CK30 Auto Shut Off #6
So far no issues with hitting the key yet. I have short legs too.
/ CK30 Auto Shut Off #7
I do this all the time. I'm thinking of taking my leg off.
/ CK30 Auto Shut Off #8
It would be nice if the key had a hinge on it. I have a key like that for one of my tool boxes. I may look around and see if I can find a blank key with a hinge and get one cut. Jimmy, you might want to keep the leg, it might come in handy. Although, you would swear I hate my fingers, I am always beating them up!
/ CK30 Auto Shut Off #9
On my 2510 my knee manages to turn the lights on.
/ CK30 Auto Shut Off #10
My CK has a nasty habit of shutting off on its on whenever I hit a large bump, especially at high speed. Haven't figured out how to avoid it. Also, when I'm turned around to look over the back, the flashers usually turn off on their own too. That switch really should be moved. The worst is when I turn real far around and start wonder why the front of the tractor is lifting. Then turn back around and realize my knee hit the loader and I was digging up the driveway.
I think all tractors have things like this. The loader stick is actually perfectly placed for normal operation, so I shouldn't complain. However, how much would adding a step to the right side really add to the overall cost? I've almost fallen flat on my face a couple times looking for a step that wasn't there.
Mine has a step on both sides, I sometimes turn the lights on or off with my knee as well but that isn't as big an issue as shutting everything down while bush hogging.
/ CK30 Auto Shut Off #12
I had the same step problem with mine so I ordered one from the dealer, only cost $50 only problem the new one is the frame dark gray and not the orange.
/ CK30 Auto Shut Off #13
Mine also has steps on each side. I guess if thats all I have to complain about is the key switch, thats a good thing. I will find a solution for sure. My only other minor complaint is the height of the FEL lever. That thing has snagged my shorts and shirt many times to the point where I almost fell. And I have torn about many a shirts so far. But, I have mine at the dealer right now and I asked them to shorten the lever so I hope that resolves that issue. All in all, minor stuff.
I got an extra couple keys from the dealer and modified one to make it more of a low profile. I cut it off short and filed the chrome off the brass and soldered it into a short copper 12 gauge shell. I deactivated the primer before heating it up or I could have just fired it off. Less of a target for my knee and looks good to boot.
/ CK30 Auto Shut Off #15
Pretty slick looking fix.
Up until this weekend I had been lucky but I have been doing a lot of land grading, leveling, root raking and I spent a lot of time sideways in the seat looking back and I managed to do the Knee bump shut-down too. Freaked me out for a bit b/c I had just said I was getting low on fuel & was going to stop & re-fill.
I totally had a panic moment thinking I had run it dry or something.
Guess I'll have to add this to my project list now too.
I cut the shell off about 1/2 an inch up from the brass and pulled the wad out and dumped out the powder. Then I gently taped the primer out with a flat punch and secured it in the vice and with a fine tooth hacksaw and a cloth over it (to block potential shrapnel in case it went off) I slowly cut (not to create any heat) the primer off, about in half and dug the powder out with a small screw driver. I then heated up the brass with a torch until the plastic started melting and then pulled it out of the brass with pliers. I then tapped the primer back in and sanded the inside well with steel wool until it was shiny. I cut and filed the key as I said and tinned the exposed brass with flux and solder. I fluxed the inside of the shell and placed the shell brass over the vice opened enough to heat the bottom and melted solder into it until it was full and then held the key into it until it cooled and hardened, a few seconds. My son gave me some mortar casings which are way cool but too big for this job...maybe the new loader control knob?
/ CK30 Auto Shut Off #18
Sounds like a delicate surgery. I would probably accidentally set it off, blow my hand off, set a fire.................... the list goes on. What about a spent cartridge? Would that work?
It would work just fine, just have a small dent in the primer. But you would likely still have to punch it out and cut it in half as the primer sticks up fairly high in the shell casing and doesn't leave much room to embed the key. I placed the key in the ignition and marked how far it went in with a fine point sharpie and added about a 1/4 inch for embedding into the solder.
/ CK30 Auto Shut Off #20
Thats cool. I hope I can get around to it one of these days. Wouldnt ya know it, it happened again to me last weekend. AH!
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
2017 Ford Fusion SE Hybrid Sedan (A61574)
2017 Ford Fusion...
2025 SF60 60in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
2025 SF60 60in...
2025 BS43 44in. Hydraulic Boxbroom Sweeper Mini Skid Steer Attachment (A61572)
2025 BS43 44in...
2009 Cummins DGFA-5764071 150kW Standby Diesel Generator (A61572)
2009 Cummins...
