LS XR4046 regen advice
/ LS XR4046 regen advice #1
fl setwork
MILTON
Kubota MX4800
I am looking at a LS 4046h with loader. Good price at $23,700 delivered. My question regards the regen method. The dealer was not much help. Any thoughts? Also he says it is the same machine as the NH boomer. The folks at NH dont think so. Any thoughts or is the dealer giving a sales pitch.
/ LS XR4046 regen advice #2
The LS XR4046 and the Boomer 47 both have the Shibaura N844L 4 cylinder engine. Both are built by LS. Regen cycles will be about every 5 hours. There is a regen inhibit switch which can be depressed to postpone the regen. I have an XR3037HC (smaller Shibaura 3 cylinder engine) with the same regen cycles. I have about 96 hours on mine so it has run the regen cycle quite a few times without any problems.
The newer LS XR3100-4100 series have the LS engine. Regen cycles on them are around every 50 hours.
Thanks George,
Not being a heavy user, will this be an issue? Seems like a lot of cycles compared to the 4100 series. I guess its all what you get used to. I do realy like the fit and finish of this tractor.
/ LS XR4046 regen advice #4
It has not been an issue for me. I'm not a heavy user either. I've seen it regen a few times at the 5 hour intervals but not every time. I'm usually busy working the loader or some attachment. The regen cycle seems to work in the background and even when in regen I don't notice any loss in power or anything. I normally run the RPM's around 2000-2200 for loader work, plowing snow, flail mower etc. and 1500-1800 for the backhoe or post hole digger. Apparently the LS engineers spent a lot of time designing their new LS engine to increase the hours between regen cycles.
I think I've only read a couple posts about tractors going into limp mode which limits the RPM's to around 1500-1800 until the cycle is complete but IMO it was due to the operator running the RPM too low. These new tier 4 engines like higher RPM to keep the temps up.
I'm very pleased with my LS.
/ LS XR4046 regen advice #5
I have to agree with you George, I think running the engine at lower RPM will cause the regen to happen earlier or more often. I just got my XR 4140 in January and of course it was new and I was unfamiliar with it so I admit I did kind of baby it a little. And it had the first regen at 27 hrs. Since then I have become much more familiar and comfortable with it and have been running at higher RPM. Curious to see how many hours I will get between first and second regen. I now have 45 hours and no second regen yet, If I can make it to 54 hours + I guess I'm doing better, working it a little harder.
/ LS XR4046 regen advice #6
I agree. My XR4145's first regen was at 40 hours, but I babied it too. Now that I'm through my first oil change and over 50 hours, I'm running at a little higher RPM. It's different than an older diesel tractor in that I used to run those only as fast as I needed to get the work done. These new engines are a little different in that they seem to like to be run at a little higher RPM. Mine is a shuttle shift so I don't have to run the RPM's as high as a hydro. Great tractor though, except for the lack of a cup holder.:drink:
/ LS XR4046 regen advice #7
Cup holder comes free with cab model. :)
/ LS XR4046 regen advice #8
Mine was going into limp on and off last fall running PTO RPM brush hogging for 12 hrs straight. Had to let it sit for over an hour each time to get it to come out. Not sure RPM's have anything to do with it other than causing it to regen more often. Should NOT go into limp from low RPM. I have NEVER shut it off while in regen either. I sit and Wait.... Wait..... Wait....Wait........
/ LS XR4046 regen advice #9
My first regen kicked in today at 16.7 hours. After reading all the posts about running at high rpms, I usually run around 2000-2400. Not sure why it happened so early for me since I try to keep the rpms up. I was running box blade at 2100 when it started. I kept working without an issue at 2100, it did not miss a beat- did not limp or give me any trouble at all. It stopped regening at 17.0.
/ LS XR4046 regen advice #10
My XR4145HC hit its first regen at ~17 hours. I run it in the 2000-2400 range but it has run at 1000-1500 for about 1.5 hours of those 17 hours as the RPM's are lowered when working with people and talking to them through the window just to make it quieter. The regen took about 15 minutes and occured while running bush hog. It didn't impact the work being done. Around 12 hours the tractor went into limp mode when the fuel filter dash light came on. I looked that up and it inidicated that the fuel filter sensor was detecting water in the filter, so I bled the water from the filter, and was back to normal. Unhappy about somehow having water in the fuel in only 12 hours of use though! Didn't go back to that gas station to get fuel.
/ LS XR4046 regen advice #11
Thanks for the info. I am worried about this limp mode problem but so far, so good. Nice to know if it happens to bleed water from filter. Be interesting to see if the different gas station solves problem- hope so.
/ LS XR4046 regen advice #12
I have a XR4145HC and my experience is regen occurs every 13-17 hours. Definately better than the every 5 hours of the previous engine, but no where near the 50 hours claimed. I run it almost constantly at 2000 RPM or higher other than when starting it and letting turbo get lubericated (per manual) and before shutdown to let turbo cool (per manual) or if trying to talk to someone through window to lower engine noise. So of a typical 17 hour run, 15+ hours is definitely 2000 RPM+ use, and I am still never getting near even 25 hours between regens, let alone 50. I am curious if any other 3100/4100 owners have actually achieved a regen delta of over 40+ hours. If there are any owners regularly getting 45+ hours, then I would start to suspect something wrong with my unit, but I think that 50 is definitely not the average and I question their truth in advertising on that one. That being said, the tractor has been great so far and when it does regen, other than the lights, I don't notice a power drop or ability to work, so its not a big deal.
/ LS XR4046 regen advice #13
I agree, Pivot. I'll let ya know if my second regen hits at 34 hours (since first hit at 17). I have a feeling the 50 number is a myth. I would like to hear from other 3100/4100 users, as well. I'll keep running at high rpms but I think the norm is going to be around 20 or less. As long as it keeps working normal, I don't mind though...
/ LS XR4046 regen advice #14
Three regens in 32 hours for me, anticipate the fourth soon at this rate. I have the same concerns although I get no codes and everything seems to run fine.
/ LS XR4046 regen advice #15
Mine is currently at 84 hours. My first regen was just before 32 hours, and the second was at 68 hours. As long as you are working and the RPM's are over 2000, it is barely noticeable. I'm beginning to suspect that fuel quality has a lot to do with regen. Around the time of my first regen, the exhaust was smoking occasionally. My dealer said that was generally a sign of poor fuel quality. Shortly after the second regen, I bought a 300-gal tank and ordered a load of off-highway ULSD. Since I started using that, I don't have the smoking issue, and my "seat of the pants" analysis seems to say that it is running better. We'll see when the next regen hits.
/ LS XR4046 regen advice #16
I had a regen close to 17 hours, now at 38 hours and haven't encountered the second. I have been keeping my RPMs higher, as others said it makes a difference.
/ LS XR4046 regen advice #17
Having owned a New Holland 1720 for the past 10 years I can attest to the durability and engineering of Shibaura. I would think that fuel quality and engine load would have the most influence on the regen cycle than anything else. I just traded for a Workmaster 50 that has a FPT Tier 4B engine that utilizes only a catalytic converter. I wanted to move up in loader capability and tractor size. I would not be at all convened about the cycle times. I would think that the 50 hour cycle time stated would be under optimal operating conditions.
/ LS XR4046 regen advice #18
Fuel, hmmmm....
Maybe it's the 10% mandated biodiesel in Minnesota.
/ LS XR4046 regen advice #20
Well guys, had my second regen at 41 hours. It seems my tractor likes to regen around every 20 hours. Not close to the 50 they advertised, but still not a big deal to me. It regened while I worked.
