Mowing Rotary cutter swing arc
/ Rotary cutter swing arc #1
JFoy
Clemmons/Lexington, NC
Kubota BX25D
I've got a Kubota BX25D and Landpride RCR1248 rotary cutter. Just started using the cutter and noticed it swings quite a ways left to right. What do you guys recommend as far as the swing arc for one?
Thanks,
JFoy
/ Rotary cutter swing arc #2
Usally somewhere in the geometry of totally up or down there is a position where the stabilizers are tighter than at any other position. I adjust my implements to have about 2-2.5 " of sway here at the most.
Then it will be just a bit more on the ground. It's rough on the tractor and equipment to have it banging around all over the place.
/ Rotary cutter swing arc #3
I prefer to keep mine mostly tight with just a smidgen of play.
/ Rotary cutter swing arc #4
I think you should tighten up your stabilizers to reduce most of the left to right play. A couple of inches is alright, but if it has enough play to get up momentum it can bend or break things, or in a very extreme instance like turning on a slope, provide just enough extra sideways force to tip a tractor.
/ Rotary cutter swing arc #5
I got rid of the turn buckle system and got some bars from Hodge, I like a bit of movement from side to side like Motownbrown.
/ Rotary cutter swing arc #7
My dad always had the turn buckle system and kept things tight without ever having any problems . As for me I keep things with a little forgiveness ( 2 or 3 inches ) and have never had a problem doing that either .
/ Rotary cutter swing arc #8
Why get rid of the turnbuckles? They allow you to set just the amount of slack you want, whether that's a very little or a lot.
I like my as tight as I can keep them without binding because my entire place is fairly steep hills, and I don't what the mower swinging around when I turn to a different side slope (the photo in my avatar is one of the most level spots on our place).
/ Rotary cutter swing arc #9
Much easier to adjust with different pieces of equipment, easier hook up and all my other tractors have the same type of stabilizer bars. It is considered a significant upgrade by most and is standard on bigger higher quality machines.
They also provide more strength in both directions.
All mine are fully adjustable, so no swing excessively on slopes or anywhere.
You really need a little play or you stand the risk of bending or stripping something more easily.
/ Rotary cutter swing arc #10
I got a pair also and it is one of the best things added to my L2501. I hated the turnbuckles. The stabilizers he builds are very heavy duty items. :thumbsup:
/ Rotary cutter swing arc #11
Why get rid of the turnbuckles? They allow you to set just the amount of slack you want, whether that's a very little or a lot. I like my as tight as I can keep them without binding because my entire place is fairly steep hills, and I don't what the mower swinging around when I turn to a different side slope (the photo in my avatar is one of the most level spots on our place).
Stabilizer bars are far superior. My Grand L came standard with stabilizer bars, but I still have to suffer through the turnbuckles on other pieces of equipment. You really don't release what you are missing until you get a set.
/ Rotary cutter swing arc #12
I also ditched my turn buckles for stabilizer bars. I can't have the momentum of a swinging brush hog throwing my poor little tractor around on my steep hills. Within the first 25 hours of use, I had lost turnbuckle parts in a very inconvenient place, which made getting off the hill and back to the barn dangerous.
I bought off-the-shelf bars at the local farm store, and cut them in the middle, overlapping them at the right length, and welded them back together. Still keep the turnbuckle setup handy for the odd impliment that doesn't fit the standard 27" wide lower link spacing.
The lower link end of the turnbuckle system is still attached and visible in the picture. It only takes a few minutes to put the turnbuckles back on when I need them.
/ Rotary cutter swing arc #14
I can see we have a lot of fans for stabilizer bars, but I still can't see why. All the photos I find show telescoping bars with pins every inch or so. How can you use a setup that leaves that much slack? I set mine up snug then back off a turn or so so they won't bind. If I left that much slack my rotary mower would be flopping all over the place every time I make a turn that changes the side slope.
I can see some convenience if the turnbuckles on your tractor has jamb nuts that require a wrench like some I see in photos. But well designed ones use a spring clip to keep the turnbuckle from turning after it's set. Simple and easy.
I see several users supporting Hodge's design. Is he still in business? I see his website is down and the domain is for sale. I can't find an image of it on the Wayback Machine later than 2013.
/ Rotary cutter swing arc #15
After 60+ years of driving tractors from our old 1955 Ford 600 through our M8540, my list of things I thought I wouldn't like or thought I'd never want is pretty darn long. It's pretty hard to know or understand until you use them. Right now we have eleven tractors the best I remember with turn buckles, solid and adjustable stabilizer bars and my preference is adjustable ones. I never have anything adjusted so tight as to prevent any lateral movement. Growing up with the old solid bars, it was pretty common to have to take a solid bar off, brace it and run over it to get it straightened out. On some tasks, we just took them off to allow proper tracking with ground engaging equipment.
Hodge has shut his site down, but he is an OTT member, so you can pm him, I've lost his email, great guy with which to deal, I bought two sets. You can sometimes get parts to cobble a set together or get OEM, but if you can't contact him.
/ Rotary cutter swing arc #16
I started driving McCormick H's and M's and IH TD-40's over 60 years ago, but of course stabilizer bars were never an issue with them. My JD 870 is the first tractor I've run with a 3-point hitch. I've used it for next to 20 years using the factory turnbuckles with no issues, so can't see a reason to change now I'm afraid.
2024 CATERPILLAR 304 EXCAVATOR (A65053)
2024 CATERPILLAR...
2006 MACK VISION (A65643)
2006 MACK VISION...
New/Unused CFG Industrial H15R Mini Excavator (A65583)
New/Unused CFG...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A65053)
2019 KOMATSU...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
