   / Harbor Freight Tools that don't suck #5,771
Yes. Just be clear that they are not going to support a 4x8 foot sheet of 12 gauge steel on edge. A foot or two of vertical height I would not be concerned about at all when using about one every foot or so along the base. Just use more of them if you have something a bit taller but they really are not designed to hold stuff that you couldn't easily hold in place with one finger if you were lucky enough to have three arms.
You have an ingenious way of cleaning out all of the metal fileings that get attached to them?
   / Harbor Freight Tools that don't suck #5,773
Those magnets might hold a smooth bar the same weight as the rebar. The ridges on the rebar prevent the magnet from getting a good grip.
Bruce
   / Harbor Freight Tools that don't suck #5,777
   / Harbor Freight Tools that don't suck #5,778
Plastic wrap.
Is that to remove the filings or to prevent them from attaching??? I can see it is a great idea to prevent filings from attaching but don't see how it would remove them.
   / Harbor Freight Tools that don't suck #5,779
Remove the filings by holding a short strip of duct tape on your finger, adhesive out, then pressing the filings.
Bruce
   / Harbor Freight Tools that don't suck #5,780
I was thinking of getting these for the purpose you describe. In your opinion they are decent tools for position of supported metal?
They work great for me used as IT previously mentioned.
24in pin on tooth excavator bucket (A56436)
24in pin on tooth...
2008 Rosenbaur Spartan Gladiator Pumper Fire Truck (A56858)
2008 Rosenbaur...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
2015 12ft Towable Hot Pressure Washer Trailer (A56857)
2015 12ft Towable...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
John Deere 5055E (A53317)
John Deere 5055E...
