   / Harbor Freight Tools that don't suck #5,771
Yes. Just be clear that they are not going to support a 4x8 foot sheet of 12 gauge steel on edge. A foot or two of vertical height I would not be concerned about at all when using about one every foot or so along the base. Just use more of them if you have something a bit taller but they really are not designed to hold stuff that you couldn't easily hold in place with one finger if you were lucky enough to have three arms.
You have an ingenious way of cleaning out all of the metal fileings that get attached to them?
   / Harbor Freight Tools that don't suck #5,773
Those magnets might hold a smooth bar the same weight as the rebar. The ridges on the rebar prevent the magnet from getting a good grip.
Bruce
   / Harbor Freight Tools that don't suck #5,777
   / Harbor Freight Tools that don't suck #5,778
Plastic wrap.
Is that to remove the filings or to prevent them from attaching??? I can see it is a great idea to prevent filings from attaching but don't see how it would remove them.
   / Harbor Freight Tools that don't suck #5,779
Remove the filings by holding a short strip of duct tape on your finger, adhesive out, then pressing the filings.
Bruce
   / Harbor Freight Tools that don't suck #5,780
I was thinking of getting these for the purpose you describe. In your opinion they are decent tools for position of supported metal?
They work great for me used as IT previously mentioned.
2015 Ford F-550 Crew Cab Godwin 184U Mason Dump Truck (A56858)
2015 Ford F-550...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
Kubota L3130 (A53317)
2009 Ford Edge Limited (A57148)
2009 Ford Edge...
CFG Industrial 12EX-ATA Mini Excavator Attachment Set (A57149)
CFG Industrial...
1986 Ford LNT9000 Dump Truck (A56436)
1986 Ford LNT9000...
