SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,557
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
I think this is exactly right. It seems the problem with poly is that "anybody" can do it, including the ones that cant empty the boot unless the instructions are on the heel. It is actually the most forgiving of installation, but this can lull the common sense.I have never heard of black PE failure. A 2.5 Mile water line that my father had installed 50 years ago has never leaked. In the area around the farm where I grew up they knifed in a complete new rural water line 6' deep and it was all black poly. My brother, who is on the home place, had branches run off to various pastures while they were there to knife it in. that was 15 years ago an no issues thus far.
i had a black poly line from the city main to my house that was about 1/4 mile long and had problems - at each of the plastic barbed fittings after about 40 years. We put in a replacement black poly with brass connectors.
the beauty to black poly is that is flexible enough to take the ground shifting as long as it is deep enough to not get crushed and there is not a sharp rock next to it.
... Use brass barbs with 100% stainless clamps doubled and set 180 degrees apart. Tighten all joints at least twice because the plastic settles in. No more than gentle curving at the joints. Exclude rocks in the 1st part of backfill.
The only failure Iv seen is on some 3/4" thin/100psi stuf that was used in the well for years and then replaced when the pump was changed. It then sat out in the weather in the woods for a long time before being re purposed. One of the surface scratches then developed into a split near a joint. ... Im not blaming the polypipe.
