Cylinder fitting source
/ Cylinder fitting source #1
City Farmer
Chesterfield, Mi
Ford 3000, 4400 & 4500TLB Case 830 Case 350 dozer
Does anyone know if they make a 90* orb to Jic fitting that swivels? The orb side has to swivel. I need a small pile of them. Parker makes the crimp on @ $20-$25 each. I'd REALLY like to avoid having special hoses made. The last time it cost me $75/hose. I need 8 for the loader.
/ Cylinder fitting source #2
Do you mean LIVE swivel (as in, swivels under pressure) or just "point it where you want it and lock it down?
/ Cylinder fitting source #6
Ahh swivel under pressure. What's the application?
The pic you showed does NOT swivel under pressure
/ Cylinder fitting source #8
What loader are you putting them on?
These are for a Ford 4500 tractor with the 740 loader. All the hoses have a 90* orb swivel under pressure fitting on the cyl. end and a jic male on the other. I need 8 hoses for the loader and 4 for the steering hoses on my New Holland 545D. I'm sick with the idea of spending $600+ on just the loader 8 hoses. They're in bad shape, the rubber is wore through and the steel wires are rusted.
/ Cylinder fitting source #12
Just did all the loader hoses on dad's 4500 last year.
No need for a live swivel. Just the 90 degree adapters like I linked first, then hoses with female JIC on each end
/ Cylinder fitting source #13
Expensive but those would work. I might have to bite the bullet and buy them. My next project will be making a hose crimper for the arbor press.
For as cheap as you can get hoses made at DHH for, it's hard to justify buying the dies just to make them yourself.
2026 Kearney 102"x32' Gooseneck Trailer (A64119)
2026 Kearney...
UNUSED WOLVERINE QC7-26-12.5G QUICK COUPLER 7 (A64281)
UNUSED WOLVERINE...
2005 Dynapac CT262 Sheep's Foot Compactor (A62679)
2005 Dynapac CT262...
UNUSED WOLVERINE PALLET FORK FRAME (A64281)
UNUSED WOLVERINE...
RoadTec RP190 (A63689)
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
