Cylinder fitting source
/ Cylinder fitting source #1
City Farmer
Chesterfield, Mi
Ford 3000, 4400 & 4500TLB Case 830 Case 350 dozer
Does anyone know if they make a 90* orb to Jic fitting that swivels? The orb side has to swivel. I need a small pile of them. Parker makes the crimp on @ $20-$25 each. I'd REALLY like to avoid having special hoses made. The last time it cost me $75/hose. I need 8 for the loader.
/ Cylinder fitting source #2
Do you mean LIVE swivel (as in, swivels under pressure) or just "point it where you want it and lock it down?
/ Cylinder fitting source #6
Ahh swivel under pressure. What's the application?
The pic you showed does NOT swivel under pressure
/ Cylinder fitting source #8
What loader are you putting them on?
These are for a Ford 4500 tractor with the 740 loader. All the hoses have a 90* orb swivel under pressure fitting on the cyl. end and a jic male on the other. I need 8 hoses for the loader and 4 for the steering hoses on my New Holland 545D. I'm sick with the idea of spending $600+ on just the loader 8 hoses. They're in bad shape, the rubber is wore through and the steel wires are rusted.
/ Cylinder fitting source #12
Just did all the loader hoses on dad's 4500 last year.
No need for a live swivel. Just the 90 degree adapters like I linked first, then hoses with female JIC on each end
/ Cylinder fitting source #13
Expensive but those would work. I might have to bite the bullet and buy them. My next project will be making a hose crimper for the arbor press.
For as cheap as you can get hoses made at DHH for, it's hard to justify buying the dies just to make them yourself.
