Honda engine shaft for pump
/ Honda engine shaft for pump #1
oldforestor
Golden Triangle KY
Kub M8560 Orange Millenium Falcon, Kub M4050 wonderful dependable relic
I have a Honda 5hp motor from a dead pressure washer. I want to put a transfer pump on it.It has a 7/8" horizontal shaft. All the trash and transfer pumps I've seen have a 3/4" shaft. ?????
Are there no pumps for 7/8 shaft????
/ Honda engine shaft for pump #4
For occasional basic (crude) coupling you can also use a short length of 3/4" hydraulic hose and either clamp onto the shafts or even drill for 1/4" hardware.
I have even seen this approach on some commercial applications that did not carry all that much torque.
For a transfer pump it would work IMO.
But I agree that Lovejoy style couplings is the best method.
Thanks for replies. I'm trying to fit the transfer pump onto the existing cart thing so inserting the shaft into the pump is a space save. I'm mulling over cranking it up and putting a file or grinder to it, then reslotting it with a dremel?
/ Honda engine shaft for pump #6
New Holland uses that on the crank arm to adjust the kicker speed.
Aaron Z
/ Honda engine shaft for pump #7
Make sure that the shaft has Imperial dimension as opposed to Metric. Closest Metric to 7/8 is 22 mm.
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63689)
Neckover GL24-2-7K...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
(APPROX. 24) 2X6X12.5 ROUGH SAWN PINE (A64276)
(APPROX. 24)...
EZ Trail 3400 Gravity Wagon (A66285)
EZ Trail 3400...
