Honda engine shaft for pump
/ Honda engine shaft for pump #1
oldforestor
Golden Triangle KY
Kub M8560 Orange Millenium Falcon, Kub M4050 wonderful dependable relic
I have a Honda 5hp motor from a dead pressure washer. I want to put a transfer pump on it.It has a 7/8" horizontal shaft. All the trash and transfer pumps I've seen have a 3/4" shaft. ?????
Are there no pumps for 7/8 shaft????
/ Honda engine shaft for pump #4
For occasional basic (crude) coupling you can also use a short length of 3/4" hydraulic hose and either clamp onto the shafts or even drill for 1/4" hardware.
I have even seen this approach on some commercial applications that did not carry all that much torque.
For a transfer pump it would work IMO.
But I agree that Lovejoy style couplings is the best method.
Thanks for replies. I'm trying to fit the transfer pump onto the existing cart thing so inserting the shaft into the pump is a space save. I'm mulling over cranking it up and putting a file or grinder to it, then reslotting it with a dremel?
/ Honda engine shaft for pump #6
New Holland uses that on the crank arm to adjust the kicker speed.
Aaron Z
/ Honda engine shaft for pump #7
Make sure that the shaft has Imperial dimension as opposed to Metric. Closest Metric to 7/8 is 22 mm.
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61573)
2005 Stertil Koni...
2013 Chevrolet Silverado Service Truck (A62613)
2013 Chevrolet...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
KMC 3386 (A64119)
KMC 3386 (A64119)
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
2018 Volkswagen Passat Sedan (A61574)
2018 Volkswagen...
