Flail Mower Let's talk flail mowers
/ Let's talk flail mowers #2,921
Thanks. I've called and left message to see it. You guys think my Kubota 3301/HST with 26 hp at PTO can handle it ok?
Can you tell what kind of cut the drum and knives are set up for?
Thanks
My L3200 (same as yours without the tier 4 junk) handles my 719 just fine, think it's 7'. Tractor is 5' wide. I go slower than with the 5' rotary cutter, but am cutting more per pass & getting a better cut.
Within reason, the limit on mowers is how much you can lift on the 3pt & maneuver with effectively, not HP. If you are short on HP, just go slower until it can spin the proper PTO RPM. Trivial with a HST, hopefully you have enough & the right gears if you have a gear machine.
/ Let's talk flail mowers #2,922
Thanks
1st: the flail mower does not have a drum. The "Long Length Knife Pairs" are referred to as side slicer knives.
They are mounted on a "Flail Mower Rotor" with no shackles/D rings.
The "Flail Mower Rotor" is actually thick tubular steel with weldments attached to the tube to anchor the side slicers.
(insert BOO HISS here) this was done by Mr. Mott to save money and in the process it made more work because longer side slicers are needed.
2nd: as long as you mow slowly with it you will be fine do not expect to cut foot tall grass unless you make several passes after readjusting the rear height gauge roller at least once.
3rd. This flail mower is a finish cut flail mower with four rows of knives. These flail mowers/thier sister mowers were mounted under IHC Cub Lowboys with the side seats and they sold many of these mowers and tractor combinations.
"Once you go flail you never go back"
"Pronovost or not at all!!!!"
/ Let's talk flail mowers #2,923
changed blades on my Alamo 74" Fine cut mower this morning. Took about 2 1/2 hrs. Not a bad job. About 4-5 knife sets were missing cotter pins and I had lost 3-4 sets of knives completely. Bought the new set from Flailmaster. Knives and pins and 200 cotter pins for less than $150.
Will need to do some mowing soon.
/ Let's talk flail mowers #2,924
Thanks! I'm meeting the guy tonight after he gets off work.
Wife asked me why I was hooking the trailer up if I was just going over to "look" at it.
She's on to me. This'll cost shoes.
/ Let's talk flail mowers #2,925
Shazzam!!!,
It appears you are looking at a MOTT INTERSTATER my friend.
If you have the time I would invest in it and with little TLC you
will have a flail mower that will outperform any rotary.
Leonz,
Thank you for the info.
I got it but not at the 300 bucks.
The gearbox and everything seems to rotate smoothly. All the knives are there but out on the ends which after reading through the first 800 posts(so far) on this thread, I see is common.
I'm not sure what the two vertical pieces are for on the back that are for an adjustable pin connection. Gauge wheels maybe?
It cost me 160.
Image1463614489.254182.jpgImage1463614502.615956.jpgImage1463614516.462436.jpgImage1463614528.351138.jpg
Headed home with it. Tickled to death.
/ Let's talk flail mowers #2,927
The vertical breckets on the back seem to be just like the ones on the bigger Alamos's...gauge wheels...not sure why you would need them since the roller pretty much takes care of that.
You stole that mower.:thumbsup:
/ Let's talk flail mowers #2,928
This looks like a SHD 96 with such brackets in the back.
/ Let's talk flail mowers #2,930
Leonz,
It cost me 160.
View attachment 469047View attachment 469048View attachment 469049View attachment 469050
You want to invest in the 2 gauge wheels to make it easier to turn and prevent gouging and mower nose diving by dips in the sod. That mower had a V belt guard on it at one time so you need to replace it from a supplier like flail master or find out if the owner still has the original.
****'s bells just tell her it was my fault and that I was passed over by the black helicopters when I told you to buy it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Don't feel bad if all she wants is shoes; The new coal stoker boiler I bought just cost me another rescue mutt mouth to feed for at least 10 years and a a trip half way to Niagara Falls, WOOOF, GRRRRR!!!!!!!!!!!!!!!!!!!!!!!! Just don't let it turn into Imelda Marcos shoe closet!!!!!!!!!!!!!!!!!!!!!!!!!!
Welcome to the Flail Mower Nation my friend you will not be dissappointed as long as you read, follow instructions on how to set up your mower, invest in fine thread nylock lock nuts and bolts for the knife hanger stations and ask questions.
leonz
/ Let's talk flail mowers #2,931
You want to invest in the 2 gauge wheels to make it easier to turn and prevent gouging and mower nose diving by dips in the sod. -----------
Image search found this from jimmysisson: http://www.tractorbynet.com/forums/attachments/258467-flail-wheels.html
/ Let's talk flail mowers #2,932
I've never understood the need/role of guide wheels on flail mowers. The rear roller, not guide wheels, maintains the proper elevation for scalp free mowing. Some say the wheels help in turns but my personal experience with a flail that doesn't have guide wheels is that I simply don't have any problem with turns. Why do only some flails have this option?
/ Let's talk flail mowers #2,933
I am just guessing but I only noticed them on the bigger/heavier mowers maybe it does help with tight turns if part of the weight is carried by the gauge wheels.:confused3:
/ Let's talk flail mowers #2,934
Shame on Me!!!!!!!!!!!!!!!!!!!!!!!!!
I forgot that the roller on these units is non adjustable
from what I remember now which required the gauge
wheels to control the mower height.
They mounted these beautiful flail mowers on a lot of
mules that were 35 HP or less-the MF135 for example
for state highway departments and they covered a lot of
ground with them as they mowed more often than they
do now and the rear wheels kept the mower stable
when backing at the same time when mowing as well.
It is a real shame that they do not invest in tracked robotic
flail mowers that can be run much more economically
than the current set ups.
The Wessex Flail mowers sold in Europe can be equipped with two or four corner
mounted gauge wheels and a hitch wheel as the flail mower height on most mowers sold across the pond have a stationary rear roller and those units are typically towed with 4 wheel drive truck or heavy 4 wheel drive 4 wheeler.
/ Let's talk flail mowers #2,935
Can you identify this model please? I just know it's 84"
/ Let's talk flail mowers #2,936
I am a new member to Flail Nation. I was able to figure out from old posts that I have an old K48 Mott flail mower. I also found Flail Master from old posts and was able to replace both blown out cutter shaft bearings and all the old battered blades. Ready to hook this up to my 35 HP tractor and want to make sure that it should handle 1K RPMs. Can someone confirm this or set me straight? Thanks
/ Let's talk flail mowers #2,937
Isn't the rear PTO on the LK3504 a standard 540 rpm?? I've never heard of a rear PTO on a Kioti that was 1K.
And, by the way, welcome to both TBN and Flail Mower Nation.
/ Let's talk flail mowers #2,938
Thanks for the welcome. My LK3504 has both 540 and 1K on the PTO. I thought 1K would cut much better, but I don't want to ruin my new parts on this old Mott.
/ Let's talk flail mowers #2,939
NOPE!!!!!!!!540 RPM only!!!!!!!!!!
I want to welcome you as the newest member of the Flail Mower Nation. No taxes are required to paid, no annual dues required. The entrance to the Flail Mower Nation is a beautiful landscaped Beer Garden where no passport is required to enter.
In the Flail Mower Nation no records of Flail Mower Nation Membership are kept or required-I am always worried about the black helicopters. Fox Mulder was right!!!!!!!!
UNUSED WOLVERINE JMR-22-8.5G SUSPENDED RIPPER (A62131)
UNUSED WOLVERINE...
Genie Z60 Articulated Boom Lift (A64047)
Genie Z60...
INOP/NON-RUNNING 2013 International DuraStar 4300 Box Truck, VIN # 1HTMMAAL0DH414751 (A61165)
INOP/NON-RUNNING...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2019 Freightliner M2 106 Box Truck, VIN # 3ALACXFC8KDLH3612 (A61165)
2019 Freightliner...
Used Landpride GR1525 Stump Grinder
Used Landpride...
