Ford 3910
/ Ford 3910
Got my parts today. :) So far everything looks great! The top link bracket looked like new and was real tight. I can't wait to get everything installed. Everything is so much more stout compared to the stuff on my 2600. This thing is going to be a real workhorse when I get it done.
/ Ford 3910
The top link is an older part, as it's lacking the higher connection point. It looks like it's going to work OK though. Plus, it was free.
Had to move the tractor to the garage at the front of the property so I could free up the garage at the house. Have to put a new transmission in my dad's truck.
I'm glad I decided to move it as it forced me to clean up the other bay so I can park the tractor there out of the elements till I can start working on it.
/ Ford 3910 #83
I got my stabilizers and hangers mounted yesterday. Old parts which were removed in pic as well.
/ Ford 3910
Got some of the hitch parts on to check fit up. Going to remove so I can put antisieze on the pins for the lower lift arm pins.
/ Ford 3910 #86
Got some of the hitch parts on to check fit up. Going to remove so I can put antisieze on the pins for the lower lift arm pins. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=465424"/>
The ole girl is getting spiffed up, nicely done. Isn't it fun when things start coming together?
/ Ford 3910
Absolutely! I just talked to a guy that had this for sale. Only wants $650 or best offer. I think it's a match made in heaven for the 3910 and my fence project. :)
/ Ford 3910 #88
Absolutely! I just talked to a guy that had this for sale. Only wants $650 or best offer. I think it's a match made in heaven for the 3910 and my fence project. :) <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=465425"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=465426"/>
I've heard good things about Danuser, they still make the F8.
/ Ford 3910 #89
How's the 3910 coming?
/ Ford 3910
Thanks for asking! I finally got all the 3 point hitch parts installed a couple of weekends ago. I was actually able bush hog a little with it and she did pretty good. Now I just need to get the nose cone, grill and clean it up real good so I can replace the fuel shutoff and throttle orings in the pump. I'll try to get a bush hog video this weekend if the rain stops long enough.
/ Ford 3910 #91
Looking good!
/ Ford 3910 #93
Thought you lost control and were running through the fence there for a second. :laughing:
You're moving at a pretty good clip. What cutter are you using. Mine won't cut tall grass/weeds going that fast.
/ Ford 3910
That's actually my wife. Lol! It's a Bushhog model 285. It does cut pretty good.
Unused 2023 Monroe Tufline TW92420 9ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
Unused 2023 Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
2005 Honda Pilot AWD SUV (A66738)
2005 Honda Pilot...
Unused 2021 Paladin QH1 3 Point Quick Hitch Tractor Attachment (A66734)
Unused 2021...
No compression. Unknown operating condition. (A64553)
No compression...
20t Ton Air/Manual Hydraulic Bottle Jack (A64557)
20t Ton Air/Manual...
