Hearing protection + Music
/ Hearing protection + Music #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I've been wearing ear buds under a simple earphone style hearing protector while mowing for long periods. I find I'm turning the music up so much to over the noise of the tractor that I'm probably damaging my ears as much with the music as I am the tractor noise.
Has anyone tried noise cancelling earphones for this application. I've tried them in the tech department stores and they seem to work over the noisy store environment. Not sure if they would work over tractor noise of hold up to sweat and abuse. They are very expensive.
Anyone tried it?
/ Hearing protection + Music #3
What about a good set on ear muffs. When I did supermarket ref. that's what I used and will probably hold up better. Rack Refrigeration can be quite loud between 500 and 1000 hp in compressor depending on store size and I just used muffs, $50 probably get a pair that will serve you well.
/ Hearing protection + Music #4
Very pleased with these simple Blue tooth sound protectors: 3M WorkTunes Wireless Hearing Protector with Bluetooth Technology - - Amazon.com
I too used earbuds under regular muffs and that really sucked, especially when I yanked the cord out of the earbuds when jumping off the tractor. These ones here have wireless blue tooth that works well, and to be honest I just listen to the radio most of the time... They are not noise cancelling per se, and they do not have booming "Beats" audio sound quality, but they do eliminate most of the brush hog noise and I can hear the music perfectly fine while not hurting my ears. They are only $80 whereas the higher dollar noise cancelling units are a couple/few hundred. I think they limited the sound output to ensure that you could not damage your hearing with the audio output. It's plenty loud for me, but some reviewers whished it had more volume. I plan on running over these with my back tires someday and did not want to feel really bad when I do that...
Read the other reviews and check 'em out!
/ Hearing protection + Music #5
When mowing, I generally put in ear plugs, then put cheap headphones over them (they don't enclose around my ears). I can hear my music well enough without damaging my ears, but my iPod is turned all the way up and it's still not ideal for clarity, but good enough to jam to and help pass the time.
I used to have a nice pair of Koss headphones that encompassed the ears completely. I wish I still had them, because I'd put them on without ear plugs first and they'd cancel enough outside noise that I wouldn't have to blast the iPod to jam while mowing.
That's what I meant by 'earphones'. I'm using what I wear when shooting.
/ Hearing protection + Music #7
You sound like me, if I don't like it I'll smash it!
Regards, Fred
/ Hearing protection + Music #8
I have the wired Worktunes and they do fine without having to turn the volume up too high. If you go with the noise cancelling, be prepared to spend enough to get the higher end ones. I've had a couple of pairs of moderately priced noise cancelling head phones (under $100) and they work fine on airplanes but are useless anywhere else. Apparently the cheaper ones are tuned to airplane noise but not other things.
/ Hearing protection + Music #9
I looked into some high quality fitted noise cancelling ear buds for motorcycling. The custom fit ones started at $300 per ear and went up from there!!! For tractor work, I'd be looking at some noise cancelling ear muffs with speakers. The ones Snowback covered above look interesting.
/ Hearing protection + Music #11
I have used 2 pair of work tunes . I am not an audiophile, but they keep the noise andet me listen to the radio-and has been pointed out previously, if they get damaged I'll only be out $50.
Will
/ Hearing protection + Music #12
Look for some ear buds that accept Comply brand foam tips - they're essentially expandable foam ear plugs with an opening in them for the audio. I have a set, compliments of the USN, that are rewired for a standard mini plug and they work great. I'm pretty sure there are commercial alternatives that also take Comply tips. You do have to replace the tips after a few uses, but they provide pretty good noise attenuation.
/ Hearing protection + Music #13
After going through 2 pairs of worktunes I tried a pair of Howard Leight Sync stereo earmuffs. Although they are wired, I tuck the wire into my shirt connected to my phone in a waist holster and haven't had any issues. They claim a maximum NRR of 25, but are probably not so good if wearing glasses. Still, I can hear the music -and equipment sounds- fine without the volume being turned all the way up, regardless of whether I'm on my tractor or using the splitter or woodchipper. I like the idea of Bluetooth, but the Syncs were under $30 when I first ordered them. I have a second pair on hand just in case.
Thanks guys. Will look into all of these options. I abused my ears when I was young (guns and rock music) so now I have hearing loss in my left ear and ringing in both ears (24/7). I now try to wear hearing protection for everything, even the shop vac and power drills, etc. Listening to music while mowing all day sure helps pass the time so a good combo will be nice.
And here is the funny thing.....for us older guys: hearing going bad so need protection. Try ear plugs. Great but no music. Try ear muffs + ear buds, works okay but my glasses make ear muffs not work as well. Go without glasses. Now have trouble seeing iPhone to turn music on. Also, have sun damage on nose and cheeks. Don't want skin cancer. Need hat while mowing. Regular hat won't fit over ear muffs and has wide brim so ear muffs don't fit over hat. Find hat big enough to fit over ear muffs. Look like doofus.
Moral of the story: I need a cab. Which I would destroy within a day.
/ Hearing protection + Music #16
Just watch out for electronic muffs that amplify low threshold sounds along with the audio input.
Howard Leight Sports work Ok on the range, cutting out gunfire.
But a lawn tractor isn't loud enough to cut out, and the audio input and microphones are live at the same time.
Meaning that as you turn up the volume of your music, your also turning up the volume of the tractor noise.
Very useless in that application, I just keep my old school muffs around for that or turn the volume off on the HL's.
Has anyone actually tried any of the high dollar models like the Bose while on a tractor?
/ Hearing protection + Music #18
Bose noise cancelling head phones work for me. Nice thing about them is you don't have to turn up the volume to enjoy the music. I was initially concerned about not being able to hear what the tractor was doing, however I developed a "feel" for what was going on with the tractor in pretty short order.
Good to know. I'm not exactly the guy your signature quote is referring to, but I'm close. I love finding a good value....especially the best bang for the buck. Sometimes you have to buy and experience the 'junk' before you find the best quality vs price point. I've always thought Bose stuff was overpriced and over-hyped but I've heard such good things about these headsets that I'm actually considering them. But the $300 price tag makes me feel faint ;-) . The Beats don't get as good reviews and cost about the same. I don't fly very often and I'm not an audiophile but I do like music and do fly occasionally so I might could justify the cost or find a used pair on eBay.
/ Hearing protection + Music #20
I've got a few items on my Amazon list to pick up. These headphones come highly rated by some woodworkers I know who use them all day in the shop. Figure they should be good for tractor use:
Howard Leight 1:(11 Sync Noise-Blocking Stereo Earmuff - Safety Ear Muffs - Amazon.com
Then use a male-to-male jack (Amazon.com: 3.5mm Stereo Male to Male Adapter: Cell Phones & Accessories) to connect to a bluetooth adaptor (Amazon.com: Outdoor Tech OT61 ADAPT - Bluetooth Adapter for 3.5mm Devices (Black): Electronics) so I can use my phone. If you want to stay wired to an iPod or something else without bluetooth, these won't be needed of course.
2017 Nissan Altima 4 door (A63118)
2017 Nissan Altima...
CAT 2 3PT HITCH BRACKET (A63745)
CAT 2 3PT HITCH...
Giyi 79" Vibrating Bucket (A62183)
Giyi 79" Vibrating...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A63118)
Neckover GL24-2-7K...
2015 BIG TEX 22GN -32 GOOSENECK (A63569)
2015 BIG TEX 22GN...
John Deere 2750 Tractor (A64047)
John Deere 2750...
