Skidding Winches
/ Skidding Winches #221
Hmmm,,, (as I ponder with my coffee...) I never considered what the differences are between a wagon vs. trailer. I see that two-wheeled vs. four-wheeled seems to be a common distinction. However, if it is a tandem axle TRAILER, that doesn't make it a wagon, right? Maybe if the axles do not articulate together as tandem axles do, then the two vs. four wheels distinction applies. Although I didn't see any reference to it, I also think the ability for the front axle to be able to turn/steer is part of their distinctive differences as well?
BarnieTrk
Yep, A wagon has a steerable front axle. trailers are all straight axles, regardless of how many there may be.
It all has to do with where you grew up;-)
/ Skidding Winches #222
BarnieTrk
I know, I thought if a tractor pulled it it's a trailer, I always considered wagons to be related to horses or my little red wagon I had back in 1965.
The best thing about tandem axle trailer is when the front wheel comes against a stump or bump the front wheel will pivot up and over, thus hauling smoother. On a single wheel wagon/trailer, the wheel comes against a stump bump, it has to lift the whole weight of the wagon/trailer to get over the stump bump, thus requires more power more traction more chances of the load shifting or falling off.
/ Skidding Winches #223
The only issue I'd have with wagon vs trailer is the loss of tongue weight, I rely on tongue weight for tractor traction. If I could afford the choice of a perfect trailer, it would be a tandem power trailer with log loader for me, with an option for a dump bed for moving dirt.
Wallenstein has exactly that without the drive wheels. They even have the option to remove the grapple and attach a backhoe bucket in its place or auger which would be awesome for fence work. LX95P/LT3HA Log Trailer/Grapple Package | Log Trailers | LX95/LT3 LOG TRAILER/GRAPPLE PACKAGES | Wallenstein Outdoor Power Equipment
Too bad the bloody things are so expensive. 14-20 grand for the trailer depending on options plus another $1500 for the dump box and another $1100 if you want the backhoe option.
/ Skidding Winches #224
For most of my childhood years, I rode on a standard frame hay wagon - then when I was 19, I did some work for a nearby farmer that had tandem axle hay wagons. WOW - did they ride smooth! I was amazed as to how tight the hay stack stayed nice & tight on that trailer! Yeah, a tandem axle hay wagon is more money - but WOW are they nice to work off of!
BarnieTrk
/ Skidding Winches #225
i dont know if anyone told you this yet but my brother use to work around big skidders and he said friday night the skidder would run the cable out put as much tension on the line as they could come monday just like new again ..take the kinks out lol
/ Skidding Winches #226
....and this technique works even better if you have a swivel at the hook end.
BarnieTrk
/ Skidding Winches #227
I'm still working on the saw scabbards. They're being painted as we speak.
What about a cup holder? Looks like you need at least one!
/ Skidding Winches #228
Yes those are nice trailers and I can almost see 14K for trailer with pulp loader but not for the basic model with no acc., it's not even a 12ft. bed. I see around 2K in materials maybe 3K if the stakes come out in two pieces, which is what I need to load and unload.
/ Skidding Winches #230
I was split between the Farmi 501 & the Wallenstein FX 90.They seemed to be similar with me leaning towards the FX 90 because of the hitch.But now with the pulling weight difference between the newer FX 85,I am leaning more towards ti Farmi 501 again.My tractor is a Kubota M6800.And I love the front and rear Diff locks.
/ Skidding Winches #231
The Wallenstein FX 110 compares to the Farmi 501 spec wise and you can probably get the FX 140 which pulls 14000 lbs for less money than the Farmi.
/ Skidding Winches #232
Does the Farmi come with a protective screen, hitch or choker chains, like the Wallenstein does?
OR are they options that push the Farmi price even higher?
Back when I bought my winch, Farmi was my second choice, and Farmi was quite a bit more money, by the time you added the options that Wallenstein already came with.
Plus I liked the idea that the Wallenstein factory was in Canada, instead across the pond like Farmi...
SR
/ Skidding Winches #233
That's the smaller of their 2 trailers. The other one has 11' bed with 11,500 lbs capacity suggested for 45 hp tractors and up. It's 20-23K depending on model.
I think one 1/2 way in between would be ideal. Seems like there is a bit of a gap between the 2
/ Skidding Winches #235
I've been checking out some pto winches, some of them have a hand remote, I seen lot's of times when getting firewood that would be some handy. The only issue that soured me is the tiny weeny buttons. The people using them were dressed up in Star Wars like suke suits doing some bare knuckle chain rapping, we'll sure if you got small hands and no gloves that would be ok. BUT.......
In my world that's not reality, suns not always shinning it's not always 40 degrees or above, lot of times it's below freezing, snow on the ground, basic cotton, flannel, wool shirt, overalls/work pants, but always and every time, XXL work gloves/winter gloves for chain rapping and cable pulling, so if I cant push the in/out button on the winch remote control with gloves on, I'm not buying.
/ Skidding Winches #236
Have you ever tried running a GPS while riding a motor bike and wearing gloves.
Stupid little touch buttons! Made for tiny woman’s fingers.
/ Skidding Winches #237
I found one, a Uniforest winch and remote that can be used with gloves, but the rest of this wood harvesting equipment is bad design, obviously they didn't contact me for input. First they take the loader off and put a half useless blade on, really, the FEL is the best thing to have in the woods, especially one with grapple.
The winch appears to run off hydraulics with the cable spooled up on front of tractor, but what erk IRK me was the cable height when winching, looked like about 2 ft. off ground, great if you want to plow a garden or gather up a brush pile between the winch and logs. I wouldn't even drive that tractor out of the factory until the get that cable up min. of 5 ft. 6 on that size tractor would be better, above ground, next have optional lower pulley on for certain winching applications, but I did like the glove operated remote.
UNIFOREST 2x85HFpro - YouTube
/ Skidding Winches #238
Not sure if that model is available in North America. Check out:
Skidding Winches | Uniforest Winches | ATV Winches | Farm Equipment | Hud-Son
/ Skidding Winches #239
Still checking out different pto winches and noticing no one's using an improved latch hook. Everyone seem's to use those same stile choker hooks, I see one guy using a choker chain with a ring instead, not for ME. I'm running 5 chokers, 4 years ago I got so fed up with those choker hooks unhooking when I hook on another tree and even worse is trying to unhook 5 hooks at the landing, I had to unhook 2 then winch up again and release...............
For the last 4 years I've been using 3 of these> Tulsa Chain Hooks, (GRADE 100 CLEVIS SLING HOOK WITH FORGED LATCH) for 5/16 chain and 2 regular choker hook on shorter chains, 5 chains in all. At first I didn't think they would hold up, but they take a pounding and it's a lot easier to unhook, just press the latch, no more fiddling diddling piddling...........
Clevis Sling Hook -
/ Skidding Winches #240
SR
When I called about purchasing a Farmi 501, the screen was an option and the choker chains. They threw in the screen, 4 chokers and shipping. I initially wanted the Wallenstein for the hitch however my PTO wasn't enough horses to run it. Very happy with the Farmi though.
2020 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 FREIGHTLINER...
IRMC High-End Massage Chair (A64047)
IRMC High-End...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2016 International DuraStar 4300 Dump Truck (A61573)
2016 International...
2007 Ford F-250 Crew Cab Pickup Truck (A61573)
2007 Ford F-250...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
