Stump grinder questions
/ Stump grinder questions #22
After materials, machining, paint, skidding/crating, the prices charged for these aren't so out of line. Getting in and lowering the price is just going to start a race to the bottom. Keep in mind; they're also giving the Feds 30% off the profits. Hard as it may seem to believe, I don't think anyone's getting rich selling 3pt stump grinders.
/ Stump grinder questions #23
I think it's the comparison to the prices of other stuff that has me stumped. Pardon the pun.
Speaking of the Feds they have these things priced as if they were all made in the People's Republic of California.
/ Stump grinder questions #24
Where as I have zero labor, zero facilities expenses, zero consumables, and zero tax, and my cost was still $2k. Mind you, I have all of those for my manufacturing business, but I built this myself so I can rent it to my stump grinding business. ;)
Gear box, teeth, pockets, steel, cylinders, fittings, valves, hoses, fasteners = $2k
You don't stay in business selling that at cost. You seem to have an unrealistic expectation of what these pieces cost; or you expect the people making them to work for P.R.C. wages. When you have a 120# wheel turning 700rpm in front of you, do you really want a $11/hr weldor doing the beads?
On one of your pictures, a set of teeth are straight instead of angled.
This is my concept for a boom. A double acting cylinder inside the tubes will extend and retract it 12". There a four single acting cylinders to lock the inner tube when cutting. Opinions?
/ Stump grinder questions #30
I wouldn't worry about the locking cylinders, and I'd go longer if you're going to bother telescoping. Use 5/16" wall mechanical tubing and size it so you can bush it with UHMW.
You really don't think the locking cylinders aren't necessary?
/ Stump grinder questions #32
3.5" cylinder generates 24klbs force at 3kpsi. It's not going to bleed down on you.
I was thinking in terms of any slop in the boom would translate into the cutting wheel doing the 'hop'.
/ Stump grinder questions #35
Yes, there are angled and straight teeth. I have no clue as to how they came up with the design, I just followed the directions they provided. Gives a wider cut in the end.
/ Stump grinder questions #36
Changes the tooth orientation to the stump and allows more even chip loads.
I wish I'd gone with 900 series teeth so I could get reverse bend pockets. Mine doesn't plunge well with the gap left with straight pockets on the OD course.
Good stuff! Thanks!
2004 VOLVO EC290B LC EXCAVATOR (A62129)
2004 VOLVO EC290B...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2008 Freightliner Allegro Bay Class A Motorhome (A61569)
2008 Freightliner...
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
