Your towing rigs and trailers
   / Your towing rigs and trailers #2,384
I too am one those crazy guys who likes the 6.0 power stroke. It's a misunderstood engine, but if you know it , it is a beast...it's my favorite pulling motor.
   / Your towing rigs and trailers #2,385
6.0's are good motors, if you deal with the weak points before major damage happens. If neglected, they will cost you big $$$$$. Can be just as reliable as a 7.3, if taken care of...
   / Your towing rigs and trailers #2,386
There is a very nice back up camera option that I found on Amazon. It plugs in to The back of your six way trailer harness. No wiring just simple unplug and plug in A Tee harness. You only have to run one main wire all the way to the dashboard for the camera. I installed one on my F1 50 and it is great automatically comes on when I put the truck in reverse. I think it was around 150 bucks. I read a bunch of reviews about the wireless ones and seemed to think that they might be problematic. I have used this one for about four months now and had no problems.
   / Your towing rigs and trailers #2,387
Can you share a link or brand?
   / Your towing rigs and trailers #2,389
like this
yes
I always liked that body style, use to have a 92 with straight 6 and loved that truck. Almost bought a 96 extended cab dually with diesel but as much as I loved the truck I needed a crew cab. Was a great feeling hoping in that truck and remembering my old truck as the interior was all red like mine was.
   / Your towing rigs and trailers #2,391
Awesome, thanks!
Yes that's it this is the exact one that I used. Very easy to install but just as a note to keep in mind: I have a extended cab 6 1/2 foot bed truck and I had enough wire with the kit to run to the left side of my dashboard. If I had a longer vehicle or wanted to go to the middle of the dashboard I would not of had enough wire and would've had to purchase the wire extension that they offer.
   / Your towing rigs and trailers #2,392
Bought my first new truck yesterday!
Here's a link to my TBN-assisted thought process: http://www.tractorbynet.com/forums/trailers-transportation/356554-questions-2016-f250.html
I replaced a 2003 F250 with frame rot .
This is a 2016 F250 XLT, 4x4, Crewcab, shortbed, SRW. Had to search to find one with the bigger 4.30 electronic locking rear axle.
Rated for 12.5k at the bumper and 15.1k with Goose or 5th wheel.
It has adjustable pedals, backup assist, snow plow prep pkg, and the XLT value pkg. I put new BFG KO2 A/T 18" tires on it. Line-x basic bedliner, B&W turnover Gooseneck hitch, and line-x'ed 3 hoop-step rails are going on in a couple weeks.
I want a wireless magnet backup camera for bumper-pull hook-ups if anyone has a recommendation.
Haven't towed with it yet. Probably next weekend.
The built-in trailer break controller (with computer managed sway control) can be pre-programmed/customized for each trailer. It even keeps track of miles for each trailer (handy for trailer maintenance I think).
Truck technology has come a long way since 2003.
Nice truck! -- and I learned a couple things from your post. 1) I didn't know that you could get the 4.30 gear ratio with a SRW truck other than a chassis build. I didn't need it but I always thought 3.73 was the top for that configuration. And 2) Didn't realize that you can track your trailer mileage, I'll have to get the manual out and see how to do that.
   / Your towing rigs and trailers #2,393
Does the inline connector have a "lock" for the trailer's plug so it can't jiggle loose? Like the spring-loaded lid does on most vehicle receptacles?
Also, tman, what is the make of your truck? Is the screen big enough and bright enough? Would you buy it again? Thanks.
   / Your towing rigs and trailers #2,394
Thanks! Not positive I needed the 4.30s either but everyone on here really recommend it. :confused3:
   / Your towing rigs and trailers #2,395
2014 F150 5.0
Kubota B2650 with Woods BBX48
Hughes 18' trailer
Sent from my iPhone using TractorByNet
   / Your towing rigs and trailers #2,396
hauled a IH 444 for a friend
   / Your towing rigs and trailers #2,397
Nice Terry. Like it was ment to be.... IH T444E engine in the truck, IH mdl 444 tractor on the trailer... coincidence? No way... *grin*
   / Your towing rigs and trailers #2,398
NOT MINE!!!
Saw this at the dealer today as I was killing some time.... Sweet rig!!!
   / Your towing rigs and trailers #2,399
NOT MINE!!!
A couple hours later, I saw this sweet right actually in action !!! Just to cool
   / Your towing rigs and trailers #2,400
This is my modest rig, 7k trailer w/brakes and Tekonsha controller.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 CATERPILLAR 308E CR EXCAVATOR (A60429)
2013 CATERPILLAR...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
159120 (A60430)
159120 (A60430)
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
