XR4150H Failure codef04
/ XR4150H Failure codef04 #1
RandyinMS
Ashland, MS
Farmall Cub
My LS has been great, I just passed 200 hours.Wouldn't run yesterday and ad a fail code Fo4 1076. dealer sent the mechanic out and it was diagnosed as a bad solenoid in the fuel system. He had to unplug the solenoid to get the tractor to run enough to load it on the trailer.
Is this a freak occurrence or has others had this issue?
Is a service call under warranty too or am out of pocket on that?
/ XR4150H Failure codef04 #2
From the manual, it looks like 1076 is related to the inlet metering valve, IMV, which controls pressure to the rail and is connected to the fuel pump. This seems to be used to avoid having a large volume of fuel return to the tank (and heat), but still retain pressure in the rail. Looks like it failed closed/open or is getting a signal to perform in a manner the ECU doesn't like.
UPDATE.
Dealer put another solenoid on the tractor it worked until the second time they tried to run it. New fuel pump ordered and on its way.
/ XR4150H Failure codef04 #4
Just out of curiosity, how did you pull the code?
/ XR4150H Failure codef04 #5
Good question.
From what I can get out of the SM it says it will blink on the LCD display, "1076" every 1/2 second. These are "suspect parameter codes" (SPC) and each one of these may have multiple "diagnostic trouble codes" (DTC) related to them. Need a communications module connected to ECU to get the DTC code.
Could be all wrong, but that's how I read it. Is this what happened?
/ XR4150H Failure codef04 #6
or was the F04 displayed also? i.e. F04 1076
that may relate to P0004?
Good question.
Yes, this is how it displayed. Dealer mechanic brought out his pc and hooked it up to confirm. Had to detach a wire to get the tractor to run enough to load it on the trailer.
/ XR4150H Failure codef04 #8
What did he plug it into on the tractor? I'd be interested to know if it is similar to the OBDII protocol for highway vehicles. Perhaps LS would sell the software and interface for the diy mechanic in the future.
Behind the lower dash panel is a plug in interface. Yes very similar to OBDII
/ XR4150H Failure codef04 #10
So I got the tractor back from the dealer Tuesday. The guys from Murphy Brothers Trading company in Boonville, MS did a great job getting this sorted and back quickly. I was able to get out prep some soil and make some beds before the rain.
/ XR4150H Failure codef04 #13
Most HD Obd II scanner will read and reset trouble codes on LS tractors my XR4040C has an unkeyed Caterpillar OBD-II socket I had to buy an adapter to a standard OBD-II connector , my china HD OBD scanner reads and resets codes as well as reads live data...haven't tried the regen function as of yet but thinking that should work ...
You can also tur the key on then off two times to reset some codes.
/ XR4150H Failure codef04 #15
Not for sure about useing key to reset OBD ...May clear light , but won't clear codes from memory....
Correct, not from memory but on occasion a sensor code might trip the "creep" mode.
1999 AMERICAN EAGLE CLASS A MOTORHOME (A65643)
1999 AMERICAN...
GREAT PLAINS TURBO-MAX 1200 - 12' VERTICAL TILLAGE (A64277)
GREAT PLAINS...
AR500 Coyote Target (A65640)
AR500 Coyote...
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
