Oil filter for New Holland 2120
   / Oil filter for New Holland 2120 #22
2120 engine oil filter is parallel to the crankshaft.
Threads on to the side of the block, end of filter is close to the lower side cover.......
You can see it to the left of the front tire.
Ed
SBA140516230 is the OEM part number.
The parts diagram on New Hollands site does show this as a spin oil filter.
I think NAPA 1329, listed at 5.8". The cross reference for Baldwin worked with the OEM number came up with B7091, and 5 13/16",
51329 came up on WIX's cross refrence for OEM SBA140516230, and 5.8"
When I find out for sure I will buy extra. I will post here, for the next guy too.
Nothing has cross referenced on the Fram website look up feature.
Who sells Wix?
   / Oil filter for New Holland 2120 #25
If you get a Napa or Carquest it might be wix...
   / Oil filter for New Holland 2120 #26
Ed
That's a late Tier I emissions 2120; 1999 or later. Different engine than the OP's 1995 model and takes a different engine oil filter.
I'm not making this stuff up; been wrenching on and selling parts for Ford and New Holland tractors for 20 years. Ed and George are confusing the issue. I don't care if the OP uses OEM, Wix, CARQUEST, NAPA or whatever. But he should use a filter correct for the application, not whatever somebody thinks fits.
   / Oil filter for New Holland 2120 #27
Sorry for trying to help. Don't mean to confuse anyone. I only replied with the filter numbers I found published on the filter cross reference sites, not what I think fits. Apparently they're all wrong.
Hopefully I get up this weekend and find out. I am going off memory, so who knows. I took pictures, but none that show it.
   / Oil filter for New Holland 2120 #29
That's a late Tier I emissions 2120; 1999 or later. Different engine than the OP's 1995 model and takes a different engine oil filter. .
Unreal! I had no idea they actually switched to different engines in the same model. I never would have that about that. thanks for posting that.
   / Oil filter for New Holland 2120 #30
I have a 1993 Ford 2120. Filter is parallel to crank. Oil filter #s I wrote down are Motorcraft FL-300 or Napa 1329. Those are a few years old but should be right. If you need a pic, let me know.
Jim
Closest one napa has is Denver. $28 plus shipping.
Do ford dealers have tractor filters or do I need to go to new holland? 50 miles away.
Jim
How many quarts of oil? Manual says 8.5 with filter. A thread said that was wrong.
   / Oil filter for New Holland 2120 #33
ford hasn't been with new holland in a loooong time.
that said.. there are many 'truck' filters that will fit many OLD ford tractors. ( motorcraft fl1a type filter is common on OLDER machines ) .. but for those .. it's cheaper to just hit walmart or the auto store.
I realized that, that is why I asked, and why before someone gave a Ford part #, I never thought of calling them. But then I thought maybe they support some old stuff. One of the filters listed for one Ford model fit Lexus, and other vehicles.
New Holland dealer can get one, will be here in by Tuesday, $29. Might as well go factory, no shipping that he mentioned. I figure even they got something else on there when I get there, the mount should be the same.
$29 for a filter!!!!
I was thinking when I find out it fits I should order a few, but then I did the math. I am curious if something else fits thats cheaper.
Baldwin on internet $14
Another site has Wix for $11.
Have to read up on filters, and find a company with good shipping rates. I don't mind spending the money, it just seems alot for an oil filter. I realize they are critical, I usually pay for the high performance ones, even though I don't know if do anything. But a Mobil 1 filter for my truck is $12.
Not to open a can of worms, any opinions on brands, or ones that consider cheap? I usually just buy big box store truck filters, so I never heard of some of these.
   / Oil filter for New Holland 2120 #37
I think 8.5 qts is correct. I can look in my manual but that sounds right. I like having a lot of oil in there, except at buying time.
Jim
   / Oil filter for New Holland 2120 #39
8.5 quarts.
No, I don't own one. But I've done more oil changes on 2120's than just about anyone that does own one.
Thanks
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
2019 JOHN DEERE 850L LGP CRAWLER DOZER (A60429)
2019 JOHN DEERE...
2013 Ford Focus Hatchback (A59231)
2013 Ford Focus...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
SKID STEER ATTACHMENT (A58214)
SKID STEER...
