Oil filter for New Holland 2120
   / Oil filter for New Holland 2120 #22
2120 engine oil filter is parallel to the crankshaft.
Threads on to the side of the block, end of filter is close to the lower side cover.......
You can see it to the left of the front tire.
Ed
SBA140516230 is the OEM part number.
The parts diagram on New Hollands site does show this as a spin oil filter.
I think NAPA 1329, listed at 5.8". The cross reference for Baldwin worked with the OEM number came up with B7091, and 5 13/16",
51329 came up on WIX's cross refrence for OEM SBA140516230, and 5.8"
When I find out for sure I will buy extra. I will post here, for the next guy too.
Nothing has cross referenced on the Fram website look up feature.
Who sells Wix?
   / Oil filter for New Holland 2120 #25
If you get a Napa or Carquest it might be wix...
   / Oil filter for New Holland 2120 #26
Ed
That's a late Tier I emissions 2120; 1999 or later. Different engine than the OP's 1995 model and takes a different engine oil filter.
I'm not making this stuff up; been wrenching on and selling parts for Ford and New Holland tractors for 20 years. Ed and George are confusing the issue. I don't care if the OP uses OEM, Wix, CARQUEST, NAPA or whatever. But he should use a filter correct for the application, not whatever somebody thinks fits.
   / Oil filter for New Holland 2120 #27
Sorry for trying to help. Don't mean to confuse anyone. I only replied with the filter numbers I found published on the filter cross reference sites, not what I think fits. Apparently they're all wrong.
Hopefully I get up this weekend and find out. I am going off memory, so who knows. I took pictures, but none that show it.
   / Oil filter for New Holland 2120 #29
That's a late Tier I emissions 2120; 1999 or later. Different engine than the OP's 1995 model and takes a different engine oil filter. .
Unreal! I had no idea they actually switched to different engines in the same model. I never would have that about that. thanks for posting that.
   / Oil filter for New Holland 2120 #30
I have a 1993 Ford 2120. Filter is parallel to crank. Oil filter #s I wrote down are Motorcraft FL-300 or Napa 1329. Those are a few years old but should be right. If you need a pic, let me know.
Jim
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
2012 JCB 8030 ZTS Mini Excavator (A55851)
2012 JCB 8030 ZTS...
Tandem Axle Rear Truck Frame (A55852)
Tandem Axle Rear...
2014 Ford Fusion SE Sedan (A55853)
2014 Ford Fusion...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
