Chipper pto driven wood chippers
/ pto driven wood chippers #101
Bad link, it's gone, sold, kaput. They don't last long anywhere.......
Yes, that was so "two days ago" ;-)
It was there when the post was made. The link is good, item sold.
They are out there, can't expect them to be held for you.
ps, It was a Wally, much like the units pictured in this thread, for $1000. The paint looked great, included a spare set of blades.
/ pto driven wood chippers #103
Glrret-Still waiting for a review ...!!! I have been torn between the 8 and the mx9900.
/ pto driven wood chippers #104
If you can handle the price, the MX9900 is the one to get. It has several design upgrades over the 8H. 4 blades instead of 2, hydrostatic drive, easy access to blades, fold up in-feed hopper (both a plus in maneuvering though the woods and smaller storage foot print), and overall just a cleaner / simpler setup.
I have one and it handles everything I have fed it, from 8" pine to 6" white oak. The only thing it doesn't like is the wild honeysuckle vines I have all over my property.
FYI, there web site is not always up to date on inventory, so call before you order.
/ pto driven wood chippers #105
I've used my 9900 for the last 2 weekend and I've chipped up 13,500(+/-) lbs of chips.... yes we weighed them. And all I can say is that this thing is a beast! It took a little getting used to when adjusting the feed/speed control and anticipating the proper speed for the type wood I was feeding it, but after the first 1 or 2 hours I think I've got it down. My wife took some pictures and videos of it in action and I'll see about posting them here later. We are doing the Back to Eden Organic Gardening, so we are going to be using a lot of wood chips.
Setup was easy, I had to cut the PTO shaft to the proper size and, add the oil to the tank then run it at a very low RPM to get the air out of the system, that took about 3-5 minutes, and it was off to the brush pile.
So far It has proven to be every bit the chipper I expected.
I'll keep you posted.
/ pto driven wood chippers #106
Always good to have member feedback...
Looks like there will be a chipper in the future...
I was thinking of the 8" Woodmax and my brother offered to go in on it if I get the 9" Woodmax... he as the L3800
/ pto driven wood chippers #107
I am also looking at the hydraulic Woodmax. The reviews are good, the price is right, and there are some video reviews online.
I love mine!
Sent from my iPhone using TractorByNet
/ pto driven wood chippers #108
The 9" Woodmax seems to have only one powered infeed roller and the 8" has two.
It would seem two would be better.
Intended use is for Christmas Tree farm management.
/ pto driven wood chippers #109
<snip> Personally if I spend a bunch of money on something I do expect it to work correctly and without issue. I know my employer does not expect me to make mistakes and leave people with a product that needs repaired. To me if the fixes are simple, why not spend the extra $5 and use locking nuts and such. <snip>
However if you are comparing "Chinese" chippers to Wallensteins etc. it is often the difference between spending 1 bunch of money or up to 3 bunches of money. For example today Circle-G lists the Jinma 8" for $1500, Chippers Direct lists the 6" Wallenstein for $4,500. And as far as "simple fixes" often the Chinese mfg. produces a reliable product with some cheap consumable parts, like belts and oil that need replacing over time anyways. Some vendors replace them before selling, others don't. But for example any tool I buy from Harbor Freight that contains oil I automatically replace the oil.
Buying a chipper really depends upon one's needs, frequency of use and, of course, budget.
In a lot of cases, renting makes a lot more sense if you have a large amount chipping to do once or twice a year. As some wrote, 3PH chippers aren't commercial units and you won't get the productivity out of them. Renting requires some planning...you'll want to chip the days you rent...minimal trimming or other work.<snip>
And renting usually means maintenance and long term storage is not your problem.
However renting also requires hauling it back and forth and using it regardless of weather. In my case my chipping site is now at least an hours drive one way from any rental place. If I had rented a 6" chipper for just 3 weekends it was going to cost me half the price of my Jinma.
Frequency can also also be critical - we used my Jinma for maybe 50 or 60 hours over the course of several months before I moved it to Mississippi, since then I've only used it maybe 10 hours but I calculate it's already paid for itself.
We'll have to disagree on that one. After using my manual feed chipper for over 10 years I can't see the point in power feed for homeowner use. For professionals with heavy usage, sure. But not for occasional use. It's not needed in my view, costs more, and provides more moving parts to fail.
With the occasional help of a "pusher pole" I've rarely seen the need for hydraulic assist.
I have to agree with Terry on this. I also have a Bear Cat with a blower. It is manual feed but it actually feeds itself. Put in the branches, logs, or whatever and they get pulled right in as long as it will fit in the shute. Sure, something like a whole Christmas tree needs a little help because you have to force it into the shute if you don't just go down the truck with a chain saw.
gg
The very nature of the chipping process is pretty much self-feeding, my only hold ups were extremely twisted weed trees.
Does anyone know someone who has bought the Nortrac unit from Northern Tools? $1900 and looks pretty lightweight.
I have been studying the Wallenstein and Woodmaxx units too. Have fourteen acres of woods ,and need to clear a road back to a pond in the middle of the woods.
Drew - don't get something where you have to lift up and feed down limbs. That will be a real pain.
<snip>
manual or hydraulic; have gone back and forth a lot. My woods are mostly pine; does that make a difference in which feature to prioritize? I try to avoid cutting down hardwoods; plenty of falldowns for firewood as it is. New place to me, really haven't got started cleaning up the areas I want to. I have some physical restrictions with severe arthritis and a weak right arm, so I'm thinking that hydraulic feed might be just what I need. I maintain my equipment well, and have sharpened my lawn mower blades all my life; so sharpening chipper blades isn't a big issue though I would always have spares to swap out, then sharpen when convenient. 20 hours until sharpening. Hmmmm. Just like in a kitchen, you really need a sharp knife both for performance and also for safety.
You would probably want hydraulic, just to assist your arm. But watch the difference between the videos on the Woodmaxx site of the WM-8M (manual) and WM-8H (hydraulic) running. It seems the only difference in getting chips made is that the hydraulic one is yellow.
I could only include 1 video;
I can't justify more than three grand for a pto chipper; I have 50hp. Not sure that gets me into a Wallenstein, probably only a Woodmax.
The other financial issue has already been covered. If these things hold their value so well, why not spend a little more because when time goes to sell, if that is your reality, you will get a substantial percentage of your original investment back. A good ROI.
The financial part I couldn't justify was when time comes to sell I'll probably be buried, so it's only my heirs getting the $$. I had to try and keep the price down so I could buy my PHD, my tiller, my Stihl 088, etc.
<snip>
This is a very expensive implement compared to others we collect in the barn. Possibility of being pennywise and pound foolish might apply here. I see models in the two to four thousand price range that all seem to offer decent value, for their price. Now I find changing belts a PITA, but I also like the shock absorbing features of belts, and this thing sure can get shocked with big logs. Except I would be making firewood out of any big hardwood; the only larger stuff going into a new chipper would be pine.
The prime reason I see for a chipper with a bigger throat is if you've got trees with branches that twist and turn.
Watch all the videos on the Woodmax site and Youtube that may help you decide. It's too bad Ranch Hand Supply stopped selling because his warehouse was about 50 miles or less north of you.
/ pto driven wood chippers #110
I do a lot of chipping of Poplar/Aspen tops and there are a lot of twisted limbs that are a pain to cut and them pick up to feed individually, so I wanted the largest opening I could get, that is one of the reasons I went with the MX9900. The roll feeder does a good job of bending, breaking and folding the limbs in. So thus far I haven't seen and issue with the single feed roller. I feel that if the roller teeth are sharp it should work well.
/ pto driven wood chippers #111
Interestingly, so does my Jinma (bend. twist and break) limbs on the infeed. I did pull the roller when I first bought it and dressed every cross bar to a sharp bevel with a hand grinder, then I relieve some spring tension so the infeed roller grabs well. It sucks everything in except maybe a large fork so I keep my Silky hand saw hanging on the dise of the chipper just in case...it's a rare case btw. The opening on the Jinma is actually 8.5" each way. Must be the Chinese 8" is an American 8.5.....:laughing:
/ pto driven wood chippers #112
I have a bush hog brand (rebranded goossen) with a big hopper feeding a hammer shredder for branches under 1.25" and a chipper chute for 5" stuff. I love the shredder. Most of what I chip is small stuff. it's fast. Nice chipper and like most mechanical feed ones, as long as the blades are sharp it pulls in fast enough.
/ pto driven wood chippers #113
The Woodmaxx 86 H has been chipping my burr oak branches. While larger branches are usually for firewood I do occasionally chip 6 inch log using a bx 2200 Kubota. The reason to go with the hydraulic feed is to regulate the speed of the chipping, important for a small tractor. This setup is working very well. Just changed blades this past weekend which is also important as sharp blades require less hp.
/ pto driven wood chippers #114
how much time does it take to change out a set of blades on the Woodmaxx for example?
I keep my mower blades very sharp; would do the same here but are they hard to get to?
no vertical hoppers for me.
I don't understand how a manual feed model can have a regulated 50ft per min feed rate.
/ pto driven wood chippers #115
Yes, the hydraulic feed control is great. I have my MX9900 on a 55HP(engine) 45HP(PTO) and I don't see a drop in RPM unless I feed a hard wood limb 7 inches of more into it, that isn't very often because anything that large is firewood. But when the occasion does arise I just slow the feed.
Another good thing about the feeder speed control is you can manage the size of the chips you want to some degree. We use a lot of chips for compost and in most cases the smaller the better, so I just slow the feeder and I can produce really fine chip/shavings. My high bush blueberry plans love the nice fine pine wood and needle shavings.
/ pto driven wood chippers #116
The Woodmaxx 86h, 4 flywheel knives are easy to change, one bolt with an 18 mm nut is removed to open the hinged clamshell housing. Each knife is held by four, 6 mm Allen bolts and a 17 mm lock nut.
It takes about 30 minutes to change out 4 blades and retorque them to 40 lbs.
The bed knife is trickier, but easier after you've done it once. It requires the removal of three 6mm Allen
bolts. To assist, use a long Allen 6mm wrench with a 25 degree taper end to fit into the narrow space from flywheel to housing. To achieve the 0.03 inch gap, a fold in half the stiff card board back from a yellow legal pad and use it as a jig to get the 0.03 gap between flywheel knife and bed knife. Torque bolts to 40 lbs.
Make sure to Air gun debris out of Allen bolt heads.
The bed knife takes about 30 min or less once you know the technique.
Tools needed:
Torque wrench
17 and 18 mm 1/2 inch sockets
18 mm wrench
6 mm long Allen, 25 degree taper helps
Leather gloves for sharp blade handling.
Use the fly wheel safety locking pin included with the machine
/ pto driven wood chippers #117
thanks, very helpful. All makes sense.
/ pto driven wood chippers #119
Tools needed:
Torque wrench
18 mm wrench
As expired (or an unwanted credit card works just a s well).... and it's easier to deal with.
/ pto driven wood chippers #120
I sharpen chipper blades for all the tree services around here....and my own too. I do long ones and short ones.
2016 Freightliner Columbia 120 Glider Day Cab Truck, VIN # 3ALXA7CG9GDGZ6492 (A61165)
2016 Freightliner...
John Deere 5101E Tractor w/ John Deere Loader (A64047)
John Deere 5101E...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2018 Ford AWD Explorer SUV (A61569)
2018 Ford AWD...
2001 International 4000 DT 466E (A60462)
2001 International...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
