Busted cruise control?
/ Busted cruise control? #11
20160504_061546.jpg this is how I ended the confusion.
/ Busted cruise control? #13
I find getting older is a matter of elimination. The more problems you can spot and eliminate, the smoother life goes. Like you, I was concerned about ripping something off the bottom of the tractor so I made this thing out of a 26"x38" piece of diamond plate. Don't know if something like this would fit on a tbl machine however.
/ Busted cruise control? #15
I never drive my tractor in a long enough stretch to use the cruise control but I love it in the winter for warming up the hydraulic oil and engine. Fire up, let it idle a minute, make sure it's in neutral then push the forward pedal all the way down and set cruise. Puts a small load on the engine and gets the hydrostatic warmed up nicely.
/ Busted cruise control? #16
I have noticed though that the cruise doesn't maintain the speed very well, it slowly drops off and needs reset frequently. Is there an adjustment for this or just one of those things?
I have the same issue with my 3316HST. Anybody have a solution?
Good idea.
/ Busted cruise control? #19
Ribbed grip, McMaster Carr part number 9692K61. Slpiis tightly over my park brake lever. Now wifey doesn't get mixed up.
thanks
Frontier AV50H (A60462)
Frontier AV50H...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
Sdlanch SDLL60 (A60463)
Sdlanch SDLL60...
1453 (A57192)
1453 (A57192)
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
