John Deere 6400 power steering Problem
/ John Deere 6400 power steering Problem #1
ghostrider89
Youngsville,La
John Deere 6400
I bought the 6400 used a few years ago, since then the steering wheel will i guess jolting to one side and if left running and not moving will continue to turn wheel until it is all the way.Does the power steering have its own pump or is it tied into all over hydros?
/ John Deere 6400 power steering Problem #2
Welcome to TBN
My knowledge of JD tractors sold after the 55 series is very limited. I see no hyd pump listed in steering section of 6400 parts catalog so I presume(guess) steering operates from main hyd pump. Parts catalog lists a "field installed check valve"(parts key 5) for steering and I wonder what it's purpose is? It appears only parts offered by JD for steering valve is a seal kit. You can view JD parts schematics at JDparts.com.
/ John Deere 6400 power steering Problem #3
Welcome to TBN
That line goes to the inlet priority valve. There is a check valve in that line near the inlet priority valve. My guess is the FI check valve is an easier way to replace a bad check in this line? Maybe saves pulling the cab?
You are correct, looks like you can't buy internal parts for the steering valve from JD. Maybe from Danfoss? Sounds like weak or broken leaf springs that are internal, there are 6.
Unused 2025 USA Attachments EB1024 24in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2025 USA...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
213101 (A64276)
213101 (A64276)
2016 CATERPILLAR 308E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
2007 JLG 450AJ TELESCOPIC BOOM LIFT (A65056)
2007 JLG 450AJ...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A66736)
2018 Chevrolet...
