Two clicks to go back
/ Two clicks to go back #1
TractorGuy
Elite Member
N. FL
John Deere 4410, John Deere 4120, Kubota LX3310 cab, John Deere F725 Front Mount Mower, Swisher 60" pull behind mower. John Deere 4310 CUT (sold), Ford New Holland 575E Cab Backhoe (sold).
Every page I visit is taking two clicks to go back on. Using Firefox 45.0.2
Only happening here.
/ Two clicks to go back #2
It's happening here too! Just started today!:confused3:
I'm also running Firefox 45.0.2.
/ Two clicks to go back #3
Two clicks on what?
Go back to what?
/ Two clicks to go back #5
The back arrow to return to previous page.
I never use the back arrow.
That takes too long and too much of my metered bandwidth, 10 gigabytes on HughesNet.
Try right click, then click "open in new tab" or "open in new window".
Or hold down the control key and click on pictures or on links to open in new tab.
This way you can open all of the pictures and leave them open until finished reading the thread, makes it easy to look at the pictures again if someone asks about it.
/ Two clicks to go back #7
That is the way I have always done it with every website I go to. 1 window and many tabs open. As I finish up a thread I close the tab by the little 'x' at the corner of the tab.
ORRRRRR they could just fix this site to work normally instead of trying to increase up their click count.
I do use the right click new tab method for opening thumbnailed images but I see no need to open a new tab for each thread since I can only read one at the time.
Guess I will update and try again.
/ Two clicks to go back #12
I was using Firefox 46.0 and after reading a post I have to double click the back arrow. I upgraded to 46.0.1 and it still does it. I tried the refresh Ctrl + F5 and cleared the cache. It just started a couple days ago around the same time as the others.
/ Two clicks to go back #13
I had upgraded to Firefox 46.0 and as of yesterday, it still needed two clicks to return
to previous page, but today, one click works fine now. It appears that the problem
has been resolved at TBN headquarters. TBN was the only web site that I experienced
the two-click problem.
/ Two clicks to go back #16
A week ago it wouldn't work no matter how many times it was clicked, now it takes twice. I just use keystrokes :ALT" = "<" (left arrow) now. It's easier and takes less time.
46.0.1 did not fix it here either.
Came on yesterday and a single click worked for about 3 times then back to requiring 2.
/ Two clicks to go back #18
Not happening on my end. What browsers are you guys using, and what ads are you seeing on the page when this happens?
/ Two clicks to go back #19
Apparently when upgrading my Firefox browser to a newer version it lost the ad block Add-ons. For those using Firefox install Adblock Plus or Adblocker Ultimate and restart Firefox. I'm back to 1 click on the back arrow now.
The ad I was seeing on the top and right side of the page was a JD ad by Lakeland Equipment
/ Two clicks to go back #20
George2615
TYVM!
I was up to 3 clicks this morning. This fixed it.
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
John Deere 8400 (A64126)
John Deere 8400...
Landoll 18' Tilloll (A66285)
Landoll 18'...
55 GALLON POLY DRUM W/ HAND PUMP (A64276)
55 GALLON POLY...
2005 Ford Explorer XLT 4x4 (A62613)
2005 Ford Explorer...
