Opinion?
/ Opinion? #1
bigsilver
Tennessee
'18 MF 4707, '67 MF 135, '16 Mahindra 2540
New poster here (I have been a member since 2008 but this is my first post). I have decided that it is time to buy a compact tractor. I original started looking at the 3616 Mahindra a few years ago (it takes me forever to buy something), so naturally I took a look at the 1500 series. I got three quotes this past Saturday. All prices are for shuttle trans and include rear filled R4 tires and FEL without any other options. I have about 15 acres total with a mix of hills (10 acres) and flat (5 acres). I will be using the machine for mid duty FEL work, finish mowing, bushhoging, driveway maintenance and hobby farming (chickens, goats, maybe a cow and pig or two). I have read just about everything on here and just really cant decide. I think the prices are good and plan to use any bargaining power to buy a finishing mower. I currently have a MF 135 (gas), 6' box blade, 6' bushhog, 6' grader and I also have access to a 5' tiller. I would like to add a 6' rake, two bottom plow, drum mower/sickle bar mower, tedder, hay rake and a square baler or small round baler in the future. Like I said just looking for opinions (aka a shove in the back).
1533 $19,300
1538 $23,300
2540 $24,500
/ Opinion? #2
All great machines. Where are you located? In TX you can get a 2538 for the price of the 1533 you note above...
The 2538 is basically the same as the 2540 but with hydrostat, no suspension seat, and it has a slightly derated loader due to the small hydrostat effect. Also less expensive. It is a very capable tractor and was priced at a healthy savings over the Mitsubishi 1500s down here. (Those are great tractors too...) Just wanted to point it out as you had interest in the 2540. I split the dealer cost to have the suspension seat added on mine and consider that a must have add on, especially when doing lots of rough work in the woods. You can also add a cruise kit for $150-$200 when mowing.
Good luck - you cannot go wrong with any the units mentioned.
/ Opinion?
Thanks for the reply. I am in TN. I have dealers for the majority of compact's 30 mins from me all located in the same city (missing kioti, and LS). I actually prefer the shuttle to the hydro that is why I priced the 2540 over the 2538. Don't have anything ageist hydro just would rather have a shuttle. I did like the layout of the 1500 series better but I like the 2540 seat, size and weight better. I also looked at a used Case farmall 50B at a different dealer. The 50B had tier 3 emissions with 87 hours on it for the same price as the 1538. The dealer I priced the mahindra (also a New Holland, Case/IH dealer) at, offered to work a deal on the 50B, after contacting the other dealer of course. I am going to use this dealer due to past experiences with them when I use to hay.
/ Opinion? #4
Understood. Only other input I have is that having owned both a Mitsubishi chassis Max 25, and a TYM chassis 2538, I can vouch for both as being comfortable and capable machines. The Mitsu's are a touch more refined in fit and finish, but I am very pleased with the TYM foundation as well, especially for the price. If you do go with either the 1538 or 2540 you'll be getting a great tractor. (I think you'll want at least a 38HP machine for six foot implements IMHO.) You also mentioned seat, size, and weight above. I think you'll find your self in the seat frequently, and the size and weight are hard to change after purchase, so perhaps let those guide your purchase and then add your cup holder and other luxury items later on! :D
/ Opinion?
Funny, I did notice no cup holder on the 2540. I have been using a piece of PVC with a cap glued on, a couple of drain holes and a bolt through the finder for years.
/ Opinion? #6
Check out the 1526. It IS the 3x16 with a new model number.
/ Opinion? #7
I recently got a 1538 shuttle so if you have any questions for that specific model let me know. I have R4s, a backhoe and FEL on mine with only 22 hours on the clock. It seems you already have your dealer all picked out and that's half the battle.
/ Opinion?
Thank you all for your input. I think the 1526 is a little on the small size HP wise. I have narrowed it down between the 1538 and the 2540. Dealer has offered to bring both units to the house and let me try them and keep whichever one I like the most.
/ Opinion? #9
"the suspension seat added on mine and consider that a must have add on"
Absolutely
Before I sold my old Kubota, I swapped its seat suspension for the "No suspension" on my Max28.
Mahindra is really cost cutting selling anything without a comfortable suspension seat.
/ Opinion? #10
Well now, there's an eager and service oriented dealer for ya. Sounds like a good one.
BTW the seat on the 1538 is decent as is, just don't sit on it with a bunch of tools in your back pocket like I did. I went with the shuttle because I didn't like the rocker pedal on the HST. I found it to be awkward and uncomfortable.
/ Opinion? #11
Agree 100% This is an excellent opportunity to decide on the machine that fits your needs and you best. Kudos to that dealer. I'll be interested in your final thoughts. Good luck!
/ Opinion? #12
Absolutely
I tend to agree. My four years with a non suspension seat on the Max 25 didn't bother me at all, but that was on a relatively manicured and smooth/maintained 2 acres. Rough ground = must have susp seat for me now. The 2540 he'll be checking out has one standard, and I think the 1538 does as well, but I'm not positive...
/ Opinion? #13
Don't know about suspension but it sits on springs and is well padded. Comfortable enough on my bottom but I bring my own padding to the party too.
/ Opinion? #14
I had the same experience with the 1538 HST pedal. On paper I loved that tractor. I had pretty much decided it was the one...and then I went to a dealer and sat on it. Well, so much for internet tractor shopping. Ergonomically that pedal is just terrible. But HST was a non-negotiable item for me, so I ended up going with the 2538HST, with the far superior side by side hydro pedals.
/ Opinion? #15
While I didn't drive a 2500 series I think the side by side would likely be a better deal too. Heck anything would be better than that poorly placed rocker doohickey, my leg started to crap up just driving it down the lot a little bit. It took maybe 100' driving in a straight line for my little voice to say, nope this just ain't gonna do. Actually unless you're doing a lot of back and forth, the shuttle is probably easier as the hand throttle is like a cruse control, so you just sit and steer. Once I get to where I'm going, I select the gear for what I'm doing if any and from there it's the shuttle. I can see where the HST would be better for scooping out horse stalls or something like that but so far I'm doing very little loader work. It's mostly all about the backhoe for me.
/ Opinion? #16
I'll take any rocker pedal setup over a shuttle with a clutch. I can and do use either style but I prefer the rocker.
I think the rocker is actually safer when using a tractor in close in areas. I KNOW whether my toe is pressing on a pedal to go frontwards or if my heel is pressing on a pedal to go backwards.
With side by side pedals, all I know is that I'm pressing a pedal. That could be an issue in a tight situation.
/ Opinion? #17
I don't see how being uncomfortable and distracted by a cramping leg could ever be considered a safe operating practice but to each his own. I simply couldn't stand the thing for the very brief time I was on it. Maybe I have longer legs or something, it's not my foot size because for my height I have a pretty small, size 9.
/ Opinion? #18
I do fine with the rocker pedal and like it. The side by side is ok too. I really enjoy loader work being easy with the hydro to. I had standard transmissions growing up, until I got my first auto and never looked back. Maybe I'm lazy lol
/ Opinion? #19
I'm 6'3", 225 lbs, size 11 foot.
What I find cramps my leg on a gear machine is when I move snow or dirt. With snow, clutch down, shift into gear, push snow with bucket, clutch down, shift into R to position, clutch down to stop, shift into first to get to where I dump, clutch up, move to dump location, clutch down to stop, dump, clutch down, shift to R, clutch up, back up, clutch down, shift into F, clutch up, repeat several hundred or a thousand times to clear a 600-800 ft driveway. Do this for an hour or so, then do the same thing for a neighbor. With deep snow, my left leg hardly ever stops going up and down. Talk about thigh burn ! When I got off the machine I could hardly walk. I did this for nearly 25 years.
Now I just gently rock my foot back and forth. I can run the machine all day without a single ache or pain.
I like the fact that I can make those wheels turn so slowly, that it's barely perceptible. I can drive up to a truck to dump with tremendous precision and not worry about hitting the truck.
And since the machine is designed to run like that, I'm not hurting a clutch disk nor worrying about wearing it out with slippage.
I will restate..... I will never have another gear again....hst is the only way to go.
/ Opinion? #20
"I'm 6'3", 225 lbs, size 11 foot." And yet you're too feeble to drive a tractor. LOL
Just yankin your chain.
2021 CAM P4EC16  16ft 8000lb Trailer w/ Ramps (A64047)
2021 CAM P4EC16...
JOHN BLUE 300 GALLON NITROGEN APPLICATOR (A63290)
JOHN BLUE 300...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
6 Row Do-All (A64047)
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
Ratchet Straps (A62183)
Ratchet Straps...
