JIC fitting size?
/ JIC fitting size? #1
myyaz33
Nebraska
TYM T273
Hopefully a cross post is ok as the TYM forum does not get a lot of traffic and this is more of a hydraulic specific question than TYM specific. I am trying to determind the size of JIC fitting on the LT200 loader on my TYM T273. The following link goes to the TYM post I made earlier and has a couple pictures of the fitting. Hoping someone can tell me how to identify the size properly.
http://www.tractorbynet.com/forums/tym-owning-operating/356933-lt200-loader-jic-fitting-size.html
/ JIC fitting size? #2
You'll need something a bit more accurate than a tape measure - also, occasionally you'll find fittings that have slightly different sized hex females but the male threads are standard - first thing is to download this
http://www.discounthydraulichose.com/v/vspfiles/downloadables/thread_guide.pdf
In it, you'll find JIC - BUT you'll ALSO find JIS fittings a few pages further along - they look identical to JIC but have slightly different thread diameters and pitches, and are NOT interchangeable with JIC fittings.
The GOOD news - if you don't already have one, a cheapie digital caliper from HF or similar will be plenty accurate to make sure your TYM did or did NOT use the JIC connectors - I heard that some Kubotas use the JIS and others use JIC's so it's easy to get confused.
The trick is to measure across the male threads of the fitting (usually you don't even need to open the connection to get at them) - then compare to the chart above - you'll know right away which type you have, and hopefully they're JIC. The JIS fittings are not NEARLY as available in most places.
HTH... Steve
/ JIC fitting size? #3
Agree, get a caliper.
5/16 is a pretty uncommon size too
/ JIC fitting size?
The other good news is that I already have a caliper so now armed with the knowledge, I can find the right size the first time. Thanks all. I will share my results when I get a chance to get back out to the shop.
/ JIC fitting size? #5
Looks like a JIC 4 from the ruler pics in other thread. That would be 1/4.
/ JIC fitting size? #6
Like it was said before, it ain't easy trying to measure hydraulics with a tape measure. There are a couple of ways to try to determine size. First look for markings on the hose - for example a 100R16-04 - the 100R16 is the type of hose, the 04 is the size of the hose. I'm sure you've noticed - manufacturers like to put lots of markings on their stuff. Trouble is most of it means nothing to us. So the markings might be different but there should be a telltale "dash size" someplace... IF the markings are not worn off :).
Second, look on the fitting itself. Any markings anywhere may help ID the fitting. Look on the nut and on the ferrule. (Note: on two-piece fittings, markings on the ferrule are generally useless) These are usually stamped in. Sometimes they are stamped in well, often the stampings are light and easily covered with grease or grime.
Often the hose and the fitting are the same dash size - such as a 1/2" hose matched with a 1/2" fitting. However it is fairly common to see a fitting markedly larger or smaller than the hose... say a 3/8" fitting on a 1/2" hose or a 5/8" fitting on a 1/2" hose. In most cases you can usually spot this difference by visually inspecting the hose and fitting. This won't help you to actually "size" either one but if you can determine either the hose size or the fitting size it may help you make an educated guess about the other.
Andy
/ JIC fitting size? #7
Hard to tell using a tape.
I actually thought it looked like the male threads where ~9/16 wide based on the tape, thus making it a -6 (3/8).
But not point in speculating if he has calipers, and the link that Bukitcase posted
/ JIC fitting size? #8
Andy
I wouldnt even attempt an educated guess on fitting size based on hose size.
It seems fairly common (at least on my equipment) that the fittings get upsized by 1. Not so common in the industrial places I have worked.
My backhoe is full of 3/4 hoses and 7/8 fittings.
Dads backhoe is 5/8 hoses and 3/4 fittings.
His international loader is 1/2 hose with 5/8 fittings
My kubota loader has 3/8 hoses with 1/2 fittings
I work with hydraulics about every day. I cannot tell the difference between a 7/8 fitting on 3/4 hose vs a 3/4 fitting on 3/4 hose by just simply looking. I still measure to confirm. So I wouldnt even try to think someone with less hydraulic experience be expected to get it right.
/ JIC fitting size?
/ JIC fitting size? #10
Yep. ...I thought so too at first looking at the 4th pic, but the 3rd pic shows a better line up and from that one its definitely not 9/16.
/ JIC fitting size? #11
G'day an easy way to check a JIC or UN O Ring fitting is the thread is unf so if a 9/16 unf nut will screw onto the fitting then it is a number 9 jic and sizings are done in 1/16th increments so if a 5/8 nut fits then it is a number 10 fitting and so on
Jon
/ JIC fitting size? #12
Jon
Not correct at all. The dash size refers to the inside diameter. Kinda hard to have a 5/8" inside diameter with 5/8 outside fittings.
A 1/2" fitting (-08) has 3/4" threads. And 9/16" threads = 5/16" (-05) fitting. (there is no -9 fitting BTW)
/ JIC fitting size? #13
Yeah I shoulda left out the 1/2" - 5/8" comparison and maybe the hose vs fitting comparison altogether. Even with a good eye this may not be easy. On the other hand, I tend to cringe when someone on the other end of the phone starts telling me what they "measured". Sometimes we can tell something if they can get a wrench on the nut. That can be fairly reliable when working with JIC fittings. That said, I don't think it hurts to at least look. Sometimes something obvious might rear its head. I've done it because it can be difficult to ID a hose over the phone.
Andy
/ JIC fitting size?
Well, the 1/4 JIC fittings came today and I was WRONG... WRONG... WRONG... The ones I bought are too small so I remeasured with the caliper. The results are posted below. I have no idea how I screwed up but I sure did and it even appears the flares are different. Looks like I will be needing to return most everything I bought. Not sure if they will take hoses back. This will set me back another week on getting the grapple finished.
Here are the new measurements for the loader fittings I still need help with.
ID- .438
OD-.498
My next post has pictures of the old fitting by the 1/4 JIC ones I purchased.
/ JIC fitting size?
Still need help identifying the correct size.
/ JIC fitting size? #16
Before you reorder fittings make sure the thread size is UNF and not MM. JIC fittings use UNF with 37 degree cone. JIS or Komatsu fittings use metric threads with a 30 degree cone. Also the Chinese use a 37 degree fitting same as JIC but with metric threads called a 74 degree cone but is very rare here in America....I know because I wound up with a hydraulic control valve with these fittings installed and had to use adaptors to make it work.
/ JIC fitting size? #17
Also I forgot to add that you can just buy JIC female/male JIC adaptors that will fit over your 1/4" JIC to go up to what ever size JIC fitting you need. You might want to look at a JIC size chart so you know you are getting the right size.
/ JIC fitting size? #18
-5 JIC
OD of the threads is supposed to be .500. You got 0.498. the difference is the thickness of a human hair. Certainly within the margin of error.
Since hoses are custom cut/made, you may still be able to use them. Just the adapters
/ JIC fitting size?
If I just use adapters should I have any concern that the opening on the jic-4 fitting is smaller than the fittings already on the loader curl. I don't want to slow the curl down, it's already to slow.
/ JIC fitting size? #20
Yes you should - keep in mind that area of a circle isn't linear relative to diameter - if you reduce diameter by 1/2, you'll get 1/4 the flow at same pressure. Looking at your pics, I'd guess the flow difference between the two would be just about DOUBLE... Steve
(a diameter change of 1.414 up or down is double or half the area)
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2025 Wolverine MCB-11-48W 48in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A61572)
2025 Wolverine...
SHOPBUILT TRI-AXLE COMBINE HI-CYCLE TRAILER (A63291)
SHOPBUILT TRI-AXLE...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
UNUSED WOLVERINE RSB78-78" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
