Siromer 204s starting problem
/ Siromer 204s starting problem #1
paulmowers
norfolk
david brown 996
Hi people!
This is a customers machine which has got me well and truly stumped, so I'll give you a rundown of proceedings.
So customer calls and says it wont start (from past experience of this tractor i'm thinking air leak in fuel system or a blocked filter), when I get there pre heaters work but crank position gives a chattering solenoid with no rotation at all, battery voltage dropping to about 7v during cranking.
Wasn't exactly 100% sure the battery had failed as I would have expected voltage to drop to 5v or lower during cranking, but what else could it be? Especially as the customer said it had been cranking slower and slower over a number of weeks, so advised him to get a replacement battery.
He did, and it still chattered when trying to start! mmmmmm.......... I go back and remove the starter for testing in the workshop, so bench test, solenoid works fine, solid movement and good switching, however the motor current draw was very high, almost welding the test lead to the terminal and the rotation was about half speed or less of the speed I would have expected, there was no instant oomph to the spin it was very high power draw and a slow spin up to its low speed.
Dismantled it and out came the smoke, brushes worn to over half length and commutator badly burnt on 1/2 of its segments.
Burnt out starter - right?
Got a new starter for it, fitted it today, it cranks slowly frequently stopping and spinning freely like its become disconnected, this one is drawing excessive power too as the supply lead started to smoke after a short time, am thinking if I'm not careful I could easily burn out another starter on this!
I am now thinking there is something major wrong with this engine, but not having much experience with these engines, (yangdong y385? I think) I don't know the most likely place to look for tightness, I mean it has been standing outside for a good couple of weeks since it broke down, is it possible rain has got down the exhaust and one cylinder has water in causing the engine to hydraulic?
Could the hydraulic pump cause these symptoms?
I know the problem, at least I think i do, the engine must be exceptionally hard to turn causing the starter to draw excessive power and burn itself out, why is the question please, anyone?
Thanks Paul
No ideas then, ok, Siromer have no idea either!
Here's a maybe for your thoughts, clutch release bearing? You have to hold the clutch down when trying to start so maybe the bearing has either seized or even worn through the release fingers if it has them, only thing is when i had a car do this many years ago it wouldn't crank with clutch down but it also almost stalled when pressing the clutch to select gear or pull away, so not 100% sure on this.
Does anyone know where the clutch inhibitor wiring goes to the switch so i can bypass it and try starting with clutch released?
Thanks paul
Well, clutch inhibitor is right under the clutch pedal arm so dead simple to bypass, oh and engine still cranks real slow with a slow grinding noise.
Removed starter from engine, connected up wiring and tried again, pinion moves out real quick and motor spins fast as usual when solenoid energised, so clutch release bearing ok and new starter motor ok.
The edge of the ring gear teeth were all a bit knocked about so spent some time with a small grinder taking the burrs off and re shaping the lead in chamfer on each one.
While doing that I turned the engine round with the aid of a large screwdriver through the starter hole,there were no tight spots during the rotation.
So starter back in and try it again.
First attempt on a heated start and it cranked normally, subsequent attempts were hit and miss, sometimes it cranked normally sometimes slow with the grinding noise.
Out of sheer frustration I turned the key to the left, unheated start and it wound over normally and started up!
So stopped and started it a few times without heat and without issues.
Now I have to try to work out how and why there should be this difference between starting with heat or without.
anyone had any experience with these?
Thanks Paul..
/ Siromer 204s starting problem #4
Glow plug (or plugs) shorted to earth, drawing excessive current when plugs & starter are engaged? Also check cables/relay in glow plug circuit.
/ Siromer 204s starting problem #5
Checked both battery cables for good contact and corrosion?
Jim
Thanks for the suggestions,
The glow plug being shorted did sound likely although I would have thought it would have manifested melted wiring or a blown fuse to be honest, but thanks for the suggestion. However the customer now reports the starter is now either missing engagement or jumping out at every 3 or 4 revolutions.
As previously mentioned I have cleaned up the lead ins on the flywheel, that is assuming there are supposed be be lead in chamfers of the flywheel teeth and they are not supposed to be square cut. If they are meant to be square cut then this is the issue especially as there will be less power during a heated start to hold the starter pinion in place.
It has had a new battery, and all battery connections have been removed, cleaned, greased and re tightened, the earth connection to chassis has been supplemented with an extra link straight to the engine.
Also he reports that after getting it started and while grass cutting he has lost all hydraulics! No implement lift and no power steering.
I am getting a bit miffed with this tractor - The two issues can't be connected, can they?
It had a new hydraulic pump on it around this time last year as the original leaked oil like a sieve!
Thanks again Paul.
/ Siromer 204s starting problem #7
possibly the hyd pump has been dead heading, thus loading the engine at startup, and this has now blown the pump. this deadheading would also cause the starter to overload and burn up
Thanks for the suggestion,
I'm not entirely familiar with the term deadheading, I assume it means the output of the pump has nowhere to go and it overpressures? Is this likely with no external attatchments and only its onboard 3pt hitch connected, I know the q/r coupling self seal ball can play up behind the dash but they were all checked before fitting the new pump last year as the very last thing i wanted was to screw a new pump as soon as fitted due to those couplings.
Wouldn't it be really sluggish to start and run if this was the case?
Its just that when it runs, it runs normally, the same as it always has.
The biggest issue with this tractor is that it is regularly costing its owner a small fortune and I cannot keep throwing new bits at it until a cure is found, its already costing £200 for the starter.
My personal thought on it is scrap it for bits and buy an old ferguson vineyard / orchard tractor, they run for years without any problems!
Thanks paul
/ Siromer 204s starting problem #9
Mybe your ext hyrauliclever is in detend and pump the oil (deadend) ....no pipes fitted at the back ?
Well update on the tractor, tonight the owner was going to drive it to my workshop so i could work on it more easily and often as time allowed, it wouldn't start, did crank but kept disengaging and spinning free, then would resort to a slow churning cranking, not quite grinding but not sounding at all right.
Some times it would just spin free.
Ive been looking past this - its a pre engaged starter!! HOW can a pre engaged starter which by definition HAS to engage before cranking spin free or disengage from the flywheel while cranking?
And its a new overpriced badly made starter from siromer.
The old starter which burnt out never behaved like this
The hydraulic issue I am fairly sure is nothing more sinister than low oil level as the owner had experienced lumpy lifting, but until the starting problem is addressed there seems little urgency in worrying about the hydraulics.
/ Siromer 204s starting problem #11
can you easily remove the hyd pump and try starting without it?
Reasonably easily, catching spilled oil during the process, but yes it is possible.
While I can see how the pump could cause the slow churning starting fault, causing excessive pressure and drag
I don't quite see how that could be the cause of a brand new starter spinning free or disengaging when cranking at normal speed.
I think I am going to try cranking it by a live wire straight to the solenoid coil terminal (eliminating all the tractors wiring and the ignition switch), just to see what it does then.
The old starter had burnt out, but by the look of it, it was the original starter from 2004, plus the brushes were worn down almost too far too contact and the commutator was badly burnt, the customer reported it had been getting slower and slower cranking until finally it just clicked when turning the key, so my guess is that the worn out brushes caused the motor burn out?
No problems with cranking (except getting slower) or non engagement or jumping out spinning free were noticed with the old starter, all of these manifested themselves with the new starter.
This is where I'm at now, as I said I think to bypass the tractor switch and wiring with a wire straight from battery to energise the solenoid, If that works then probably a new ign switch and rewiring, or the new starter is either wrong for that tractor or faulty from new!
Cheers Paul.
/ Siromer 204s starting problem #13
if you think it is the new starter, open it up and check the brushes, and put a little lube on the shaft at the Bendix drive. is it a Chinese starter?
Yes Scottie, it is a genuine chinese starter.
I now have it at my workshop which is going to make fixing it so much easier, it only lives 1/2 mile from me but loading gear into my truck, trundling over there, then realising I'd forgot something I needed!!! Somewhat time consuming and unproductive!
So anyhow the owner tried starting it day before yesterday with no luck, cranked without heat but kept disengaging at the almost running point! Slow churn with heat.
Last night I went to try the wire trick from batt+ on solenoid to energise terminal, It cranked perfectly and never disengaged, it still plays up on the keyswitch but it started by heating on key, then cranking and he drove to the workshop.
So I think that rules out a faulty starter, it is looking like I need to do a bit of rewiring and possibly replace the ignition switch.
At least that seems to rule out anything major like ring gear damage!
Cheers Paul
I have now got to the bottom of this tractors issues - so am writing an update in case anyone else has similar issues.
It turned out that the genuine siromer new starter was either badly made or badly stored!
After hours of checking and replacing numerous connections and inline fuses I pulled the starter apart, desoldered the solenoid end cap and you would have been shocked at the amount of white corrosion that fell out!
Corrosion and burnt connections where the disc had been trying to make good contact with the contacts, a good clean up and reasemble, refit to the tractor and no sign of the previous slow churning crank or disengaging that had been evident, with or without heat a good reliable cranking over and it started!
I think the biggest lesson I have learnt here is NEVER trust a new chinese spare part!
The loss of hydraulics was caused by wear in the centre of the drive shaft to the pump, there is a large screwdriver slot in the end of the shaft with 2 drive lugs machined in it, these had worn away so the shaft was spinning without turning the pump!
I removed the shaft and tested hardness with a file and it didn't seem particularly hard so removed the bearings and gear and built up the worn parts with weld and filed back to profile, reasembled and we have working 3p hitch and power steering!
The oil level wasn't anywhere near low - so wrong on that one!
Thanks for all the advice Paul.
/ Siromer 204s starting problem #16
its really no big surprise, I have seen this on several "new" Chinese starters before. glad it worked out for you. the pump drive issue has also surfaced before
2019 Chevrolet Express 2500 Cargo Van (A64556)
2019 Chevrolet...
1992 Kenworth T600 Semi Truck (A66285)
1992 Kenworth T600...
2016 Ford F-250 Ext. Cab Pickup Truck (A64556)
2016 Ford F-250...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2017 Forest River Rockwood HW275 S/A Pop Up Camper Trailer (A64557)
2017 Forest River...
2013 Chevrolet Tahoe SUV (A64194)
2013 Chevrolet...
