Drilling a small hole thru backhoe boom?
/ Drilling a small hole thru backhoe boom? #1
jim_wilson
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I'm contemplating going hydraulic on my backhoe grapple. One of the things I'm trying to figure out - is how to route some of the hydraulic lines down to the cylinder and clamp them to the backhoe arm(s).
The most direct and simplest way in one case - would be to drill a hole (like a 1/4" hole) thru the dipperstick so that I could just use a bolt to hold a bracket against the dipperstick which would locate the hydraulic line(s).
My metalworking sense tells me that this is not that big of a deal, I'm not going to weaken the dipper stick at all. But I'm wondering if I'm missing something..........
/ Drilling a small hole thru backhoe boom? #2
Don't drill... Use Click Bond studs! PM me.
/ Drilling a small hole thru backhoe boom? #3
Couldn't you tack weld the bracket.
/ Drilling a small hole thru backhoe boom? #4
I would weld some bolts to the arm rather than drill
/ Drilling a small hole thru backhoe boom? #5
I don't think you would harm the backhoe in any way by drilling a hole, welding on a bracket etc. I would go for the welding since that is what I did for a living a couple of centuries ago. You may or may not have that ability so go with whatever you want. Just make sure that any water that may enter the hole has a place to drain out.
/ Drilling a small hole thru backhoe boom? #6
I like using these weld on hose brackets. They may protrude too much for your application, though.
Terry
/ Drilling a small hole thru backhoe boom? #7
The problem with welding is it messes up the paint. Putting in a small bolt won't hurt anything.
/ Drilling a small hole thru backhoe boom? #8
Tack welding wouldn't get hot enough to mess up much paint. You could easily grind and repaint it.
/ Drilling a small hole thru backhoe boom? #9
Round holes do not weaken the structure.
Proof is that stop drilling is the method of controlling cracks.
Lots of aircraft structural parts have all kinds of round holes to lighten the component with a wing spar being the prime example.
In fairness I must add the round hole should be 'nick free' as nicks do start cracks.
/ Drilling a small hole thru backhoe boom? #11
I posted this question on the vendors web site but do it here for benefit of TBN. What is the meaning of single wire and two wire in the descriptions of those clamps Cord gave us the link to at Surplus center?
/ Drilling a small hole thru backhoe boom? #12
Stauff Clamps (made in Germany) are the original and considered the best. Many different sizes and styles to suit tubing, piping, single, double line runs, etc. They typically are attached via weld on base. They are now incorporating Click Bond adhesive and fixturing technology so no welding/drilling required to mount.
STAUFF Bond Demo - YouTube
Stauff
If anyone is interested, PM me and I will send you more details via email. Can't figure out how to post a pdf file.
/ Drilling a small hole thru backhoe boom? #13
You might be able to piggyback on brackets for the thumb cylinder and for the bucket cylinder hoses. That is what I did. No welding or drilling needed.
/ Drilling a small hole thru backhoe boom? #14
Single wire:
One braid of high tensile steel wire reinforcement
Two wire:
Two braids of high tensile steel wire reinforcement
54in Wagon Wheel (A65583)
54in Wagon Wheel...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
(5) Texas Built 25' Stand Alone Livestock Panels (A66408)
(5) Texas Built...
Grain-O-Vator Silage / Feed Wagon (A66408)
Grain-O-Vator...
Farm Hand Silage Wagon on John Deere Running Gear (A65640)
Farm Hand Silage...
2022 EZ-GO ELITE...
