Frank Sorbello
Gold Member
- Joined
- Jul 12, 2011
- Messages
- 363
- Tractor
- Power Trac PT-422
Getting ready to pull the 22hp Robin and install 25 actually 23.5hp Kohler in 422. So far I have the muffler off, battery out, gas tank and bracket out, throttle and choke cables disconnected, battery cables disconnected.
Terry had said to loosen the bolt engine bolts. Then I can slide the motor forward a couple inches that will help in removing the back pump. Should I loosen them where they bolt onto the engine stand? I have hydraulic pumps on the front and back of the engine. The pump on the back looks easy enough. There is a coupler on the front that I am not familiar with unhooking.
I also see I have a lot of wear on the two hydraulic hoses that feed the oil cooler. I better replace them before I put the new engine in.
