yanmar 1500 pto
/ yanmar 1500 pto #1
james waters
whitesville,ny
yanmar 1500
hi everyone. on my 1500 I cannot get the pto to stop . it will only stop when
I step on the clutch. any info on this and how the pto operating lever is suppose
to work would be great.
thanks
jim
/ yanmar 1500 pto #2
More info needed. What happens when you put it in neutral? Is there an implement attached?
/ yanmar 1500 pto #4
Does the PTO continue to turn in neutral when it is under a load? It could just be spinning because of the friction in the gearbox and will stop if it gets any resistance.
/ yanmar 1500 pto
I have no implements for it. and with the decal above I will check it out. I tried to stall it with my foot and I cant. but I will try again in the neutral position. I thought it was just a 2 speed pto and I could not stop it in the center position. will post again. thanks
/ yanmar 1500 pto
I could not get the pto to stop. So I got to forcing the lever stalled the tractor now the pto is stopped and when I step on clutch and engage it. It stalls the tractor. And I was off the tractor with it idling and moved the lever and it stalled the tractor now this is were iam at. What is behind the lever controls anyone know
/ yanmar 1500 pto
The only detent detected is placing the lever forward. Which according to the lable is position one
/ yanmar 1500 pto #8
Sounds to me like your going to dig in. I am not that familiar with the 1500 but looking at part drawings I would think removing the shifter housing #29 might let you see what is going on. Don't know that, someone may know better. TRANMSISSION_CASE_G: Yanmar Tractor Parts
/ yanmar 1500 pto
Hope I get some more feedback. I think iam going to bite the Bullitt and buy the service manual
/ yanmar 1500 pto #10
TAke the cover off. worst case you have to clean it up and put some silicone on it and reseal it.
You can pull the whole PTo off the back as an assembly, that is if its like the 2000.
/ yanmar 1500 pto #11
What do you mean by "forcing the lever"? (To do what?).
/ yanmar 1500 pto
I put the lever in another position while the tractor was idling and the pto was running. Did not use the clutch. Now it hates me but no one will get hurt around it. I will get a service manual and figure it out unless someone can get me some info. Manual is 50 bucks
/ yanmar 1500 pto #13
Just curiosity. What manual is closest to your 1500?
/ yanmar 1500 pto #14
The 195 will be the closest but I honestly don't think a service manual is going to help much in this case. I think a parts breakdown will be the most help.
/ yanmar 1500 pto
hey guys how do I post pictures in here. I found my problem and this will help someone in the future.
2017 Xtreme Telescopic Telehandler (A60352)
2017 Xtreme...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
ATS ATS-PC90 Heavy Duty Plate Compactor (A62679)
ATS ATS-PC90 Heavy...
Buckhorn Poly Feed Box (A66408)
Buckhorn Poly Feed...
Bobcat S66 Skid Steer (A63689)
Bobcat S66 Skid...
2017 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 MACK CXU613...
