Dump trailer for hauling
/ Dump trailer for hauling #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I currently have a 18' (12k) eqpt trailer and am thinking about getting rid of it for a 16' or so foot dump trailer. I use my current trailer about 1 time a year to haul my MX5100 and was wondering how a dump trailer would do for that use? I am also thinking hard about getting a Mini Ex next year (8000lb machine) and also was wondering what you all thought about hauling a mini in a dump.
/ Dump trailer for hauling #2
I just replied to another post of a similar nature. I have a Cross Country 16' 13.5K dump (10K load rated) and a PJ 22' 14K full tilt bed. I have hauled my tractor in the dump and it hauls it fine. The downfalls I have are 1) Tight quarters when I have to climb in the dump to chain down the tractor. 2) Steep approach angle due to short 5' ramps. 3) 16' dump doesn't give much room to move the tractor fore/aft to balance the load especially with an attachment. 4) I don't use my BH that often off my property but I cannot load it in the dump due to the approach angle the BH will drag and if I could get it loaded I don't know how much tongue weight I'll lose due to the extra BH weight in back.
My opinion would be to keep the eqpt trailer.
/ Dump trailer for hauling #3
For hauling the tractor only once a year it probably doesn't make much difference, but what other uses would you have for the dump trailer? I have a 14K 16' Load Trail dump trailer and it's incredibly handy for a lot of things. I planned to use it mostly for moving fill and brush, but absolutely love it when I have to run to Menards to pick up lumber, insulation, etc....open the tailgate, slide everything in, close the tailgate, unroll the tarp, secure the tarp and drive off. Every time to go to places like that to pick up supplies the guys in the lumber yard always comment how convenient it is.
As far as hauling a mini-ex, I'm sure it would be fine, and if you stick to machines in the 8,000lb range you'll be okay. Mine weighs roughly 4,300lbs empty (scissor lift, 3-way tailgate, etc), so that would leave you with a little wiggle room.
Thanks!
I mainly want it to haul gravel and fill. We have about ½ a mile of gravel driveway and grave around two buildings so it always seems like we need some somewhere. I am also filling in a big area so a dump would make that a LOT easier!. Never really thought about for hauling wood - that could also be handy. I normally use my aluminum ATV trailer but the dump would be great!
As for hauling, I am looking at Kubota KX71's (used) as it fits perfectly for what I want so you are right ti does leave some room on the capacity for safety which I really like.
Thanks for the info! I appreciate your input
/ Dump trailer for hauling #5
So, why don't you back it in and see how it does that way...
SR
/ Dump trailer for hauling #6
SR
Hard to back in because I have a cab tractor and have to get out to move the BH. Plus, 16' is a little short with the loader and BH on. Since I have both trailers its much easier to use the PJ for hauling equipment and easier and faster to chain down.
/ Dump trailer for hauling #7
I have the same trailer and highly recommend it. Has never failed to lift the heaviest load if I have good battery. Comes fully equipped with 3 way gate, ramps, and tarp. I chain the tailgate to about 5 inches and am able to spread material very evenly if on level ground. Haul my L3901 with FEL no problem - not enough room to carry rear attachment. Well maybe if i put the bucket on the goose neck.
Thanks!
I did some measuring and the tractor and loader will fit in the 16' no problem - just need it to be 84" wide (back tires are wide).
Other than that it looks like it would work great for the little bit of tractor hauling I do. mainly want it if I need to take the machine in due to a problem as otherwise I really don't haul it much. The Mini Ex maybe a different story - I can see where I maybe moving it monthly but still not a lot in the grand scheme of things.
What have you found to be the best width?
Been doing some looking and thinking hard about just keeping the Eqpt trailer and getting a dump (hate to add another trailer to the collection but....)
Now the question is do you normally run out of capacity or out or room for the material? I will haul gravel, and dirt most of the time. maybe mulch sometimes but not enough that I am concerned about that. Was kicking around getting a 12' 12k because of the increased maneuverability or maybe a 14' 12k - what are your thoughts ?
/ Dump trailer for hauling #10
Seems it is easy to overload a dump with gravel... so heavier GVW is better except in my state over 10k and then you need commercial which is a deal killer for many... I do know some that keep their equipment spotless, only use it for personal use and have never had an issue towing a 14k trailer without a CDL...
As to capacity... the only time I loaned out my trailer to the son of my neighbor who has his CDL and works in logging it came back damaged... it is a PJ
So I happened to see him yesterday and he is buying another piece of equipment and asked about my trailer... told him the equipment is too heavy and he said not anymore than what he hauled last time on 14 miles of dirt roads...
He said my trailer has two 7k axles and I said it has two 6k axles... so we went over to the trailer and he was wrong... I have two 6k axles and is plated for 9,990.
So this is what can happen when you loan your equipment... grossly overloaded and used on poor washboard dirt roads in the mountains...
/ Dump trailer for hauling #11
For a dump I wouldn't want anything smaller than a 14' 14K. They weigh about 4200# empty leaving 5 tons of payload. Anything lighter is just too easy to overload.
Chris
/ Dump trailer for hauling #12
I think you're more likely to run out of capacity than room with the longer trailers for any given length, but that can vary quite a bit. For example, my 16' trailer holds 8 cubic yards if it was completely full. Figure you won't get it completely full, so 7 yards. If I get a load of 21AA limestone gravel it's about 1.5 tons per cubic yard when dumped in a pile, which works out to 10,500lbs for 7 yards. The trailer weighs 4,300lbs, so I'd be over weight by 800lbs or more.
I will say that a 12' model would probably be a fair amount more maneuverable, but it sure is nice to have the extra length when you need it.
/ Dump trailer for hauling #13
Funny how perspective changes the way stuff looks....
/ Dump trailer for hauling #14
I have a 12', 10,000 lb dump trailer that only weighs 2000lb, giving 8000 lb capacity. While I know that this is smaller than the 14,000 lb trailers you guys are contemplating, your payloads are only around 2000 lb higher given the heavier construction of the bigger trailers.
I use mine primarily for building materials, and when I built the house in CA it was very valuable for taking construction debris to the dump. About 100 trips in 2 years.
Since there was a quarry very near to the dump, there were a lot of return trips where I hauled gravel back rather than just bringing the empty trailer back. But, once that job was over and we moved to Oregon, taking any trailer to just to pick up gravel is a losing proposition. I can get 10 yards delivered in a tandem dump truck for a $70.00 delivery charge. This is 30,000 lb. If I take my trailer to the quarry, that is a minimum of 4 round trips, probably 5 since I try to stay enough under the max capacity to be legal all the time. I would burn more than $70 in diesel making than many trips, not to mention the value of my time.
Plus the delivery driver can chain his tailgate and spread any thickness of gravel I want, with expertise that comes only with daily practice.
If you need a dump trailer for other reasons, by all means get one, but my experience is that even with a dump, going to fetch gravel is not a very appealing proposition.
Don't need 10 yards all at once? The solution is simple. A gravel pile in an out of the way place is very handy to have on hand for many projects. I usually have a pile of 3/4 minus, and a pile of crushed clean for drainage.
I do see your point on the cost of a trailer vs delivery and the trailer is by far more expensive. The big advantage to me is getting what I need when I want it. We often need a ton or two of this or that for a project and that is where the trailer would be great. I also have an area where I can get all the dirt I want so I figure the trailer would be real handy there.
I also took a few more measurements and found the info I found on line about the width of my tractor was wrong - 83" will be fine so I am back looking at the 16' trailer.
What should be on my list of MUST haves? Anything to avoid? One ram or Two, scissor or no scissor? Etc?
Thanks guys
That trailer looks massive compared to the tractor. I can't even think about using one around the property behind our tractor, we are way to steep. Think the trailer my "dump" my tractor on our hills! That is some nice flat land GManBart, I wish I had just 2 acres like that!
/ Dump trailer for hauling #17
MY problem with those trailers is, they don't dump high enough!
Wet/damp dirt doesn't want to come out of them...
SR
/ Dump trailer for hauling #18
...What should be on my list of MUST haves? Anything to avoid? One ram or Two, scissor or no scissor? Etc?
Thanks guys
The scissor is more complex, but has the great advantage that the bed will not tilt on its own from having a poor weight distribution. If you are using it to haul equipment, this is important, because there always comes a time during loading when all of the weight is in the back of the trailer. Scissor types can take this, direct acting ram types will tilt at this point, which can lead to a very dangerous situation, with you sitting right on top of that danger while driving the equipment into the trailer.
/ Dump trailer for hauling #19
Been doing some looking and thinking hard about just keeping the Eqpt trailer and getting a dump (hate to add another trailer to the collection but....) Now the question is do you normally run out of capacity or out or room for the material? I will haul gravel, and dirt most of the time. maybe mulch sometimes but not enough that I am concerned about that. Was kicking around getting a 12' 12k because of the increased maneuverability or maybe a 14' 12k - what are your thoughts ?
I think you will run out of capacity first. I have a Chevy 3500 dump for hauling stuff. I might belong in the towing something wrong thread, but I'll haul 5 ton on the truck although I try to limit it to 3 tons. With 3 ton of gravel the bed is maybe 1/4 full. I haven't ran across scales with a load of dirt, but a heaping load is 3-4 tons. A heaping load of logs is 3-4 tons. With mulch you'd probably run out of room first.
/ Dump trailer for hauling #20
I had a 16' PJ gooseneck lo pro dump trailer. 15 and change GVWR. Really nice trailer and hauled my M59 backhoe well. As for hauling dirt I think it held around 8 yards if full. Hauling dirt you could only put about 5 yards in it without being over weight. If you got around 6 yards it had difficulty lifting to dump. We would haul 6-7 yards of dirt moving it around or property by heaping it at the back of the trailer and leaving the front empty. When hauling gravel the pit is 25 miles away and we would only put 4 yards so we didn't go overweight.
The 16' is great for the size and loading equipment or hauling light things like mulch but if you are focusing on hauling dirt and gravel a 12' trailer would probably fit all you could haul.
2019 Nissan Sentra (A61574)
2019 Nissan Sentra...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
2001 John Deere 1770 Planter (A63111)
2001 John Deere...
UNUSED IRMC HIGH-END MASSAGE CHAIR (A64281)
UNUSED IRMC...
2014 Jacobsen LF510 5 Gang 100in. Commercial Reel Mower (A61572)
2014 Jacobsen...
